Need help
Need help
Hi I'm new to this forums but I bought a 84 cutlass with a 72 olds 350 that had starter problems but fixed it. Last week I took it out to a car show in the mornin it ran fine all day till at night on the way back it started actin like it was runnin out of gas stopped at a gas station and pumped gas turned it on around 25-30 mph it did the same thing again so I pulled over and towed it home . The next mornin I notice the alt. belt fell off the bottom pulley but car still turns on
thanks for any help
thanks for any help
Ok well I put everything back together and it started up fine got it on the road and did the same thing when it's warm it goes up to 35-40mph and when it get to normal operating temp it only gets up to 25-30 or before it goes into 2nd gear ........ I change the gas filter I'm think about the gas pump but i don't know any had this problem before ????
Or are you saying something else?
Does it ever go faster than 45mph? When? What happens when it does?
Does it have HEI or not?
Is English not your native language? If not, which language do you speak comprehensibly?
