Suggestions for choosing the right Hydraulic Roller Cam
Old Jan 31, 2014 | 03:49 PM
HitTheHole's Avatar
Here's what I've got:
1970 Oldsmobile Cutlass Convertible w/350
TH350 Transmission has been rebuilt and my transmission specialist says he can custom build my torque converter to whatever I want
Type "O" rear axle has 3.23 Posi installed, 26.1" to 26.5" tire height all the way around (as yet undecided)
#6 heads have been ported and fitted with 2.0"/1.65" valves and Crane Energizer 1.65 ratio aluminum roller rockers
Reconditioned race rods, Probe Pistons, head gaskets, etc. result in Compression Ration of 9.7:1
Edelbrock RPM Performer Manifold with Edelbrock Thunder Series AVS 650 cfm carburetor, electric choke
Thornton High-Performance Exhaust Manifolds
Magnaflow 2.5" dual exhaust
HEI distributor
Assuming I'm sticking with what I've got, I'm trying to decide between Comp Cams XR276HR and XR262HR (both hydraulic roller cams). I want to be able to "break the tires loose and get up 'n go". I'd prefer not to have a rough, lopey cam but don't mind a mild "muscle car" idle.
Thoughts and/or suggestions are MUCH appreciated.
Old Jan 31, 2014 | 05:37 PM
cutlassefi's Avatar
You have ported heads, those cams don't have much lift to take advantage of that. I can grind you whatever want but no matter what put some more lift in it.
Old Jan 31, 2014 | 05:47 PM
ctosiflying's Avatar
HittheHole, Go with Cutlassefi's recommendations. Mark is a wealth of knowledge always looking to help with any questions you have. He ground me a custom cam for my 455. I got it running and it sounds great.
check out the video. I asked for the same....Roast the tires but don't shake the teeth out of my head. Lol
Old Jan 31, 2014 | 09:23 PM
HitTheHole's Avatar
That is just WAAAAYYYY too rough of an idle for me. It would drive me crazy.
Old Feb 1, 2014 | 01:31 AM
Fullsizelover's Avatar
There is a guy selling his roller here: https://classicoldsmobile.com/forums...oller-cam.html
That Lunati has more lift than the Comp Cams, and fits right between the 262 and 276.
I looked at the XR262 myself but choose the Lunati 60810 because of higher lift, 112 vs 110 LSA (still has to be put in the car though).
Only thing I don't know is how much valve lift the heads can take before the retainer hits the valve guide (has to be cut).
Old Feb 1, 2014 | 06:53 AM
cutlassefi's Avatar
I can do anything you want, mild to wild. And depending on the combination, you can do things to make it "sound" nastier than it behaves.
Old Feb 1, 2014 | 07:47 AM
captjim's Avatar
Isn't one of the benefits of a roller that you get the best of both worlds, power and manners?
Old Feb 1, 2014 | 12:04 PM
cutlassefi's Avatar
Hmmmm not always. Apples to apples, a roller CAN give you more Hp/tq. But you can over cam something just as easy with a roller as you can a flat tappet.
But most comparable roller profiles offer more lift without the added duration. That's where the potential increase vs drivability is, especially with a good flowing head.
442garage
Aug 9, 2013 07:13 AM
rcdynamic88
Jul 18, 2013 05:01 AM
fly1
Dec 8, 2010 07:07 PM
442garage
Oct 20, 2008 10:25 AM
70cutty
Aug 13, 2008 05:48 AM
