hydraulic roller cam
Old Dec 5, 2010 | 08:30 PM
fly1's Avatar
who makes a good street strip hydraulic roller cam for BBO
Old Dec 6, 2010 | 04:38 AM
cutlassefi's Avatar
Need all you engine/vehicle specs. I'm an Erson dealer but anyone will need all your info first.
Old Dec 6, 2010 | 05:41 AM
WMACHINES's Avatar
I like Bullet cams and Dave Smith camshafts. I'd call BTR, Bill would give you a great recommendation on camshaft and application. http://www.btrperformance.com/
Old Dec 6, 2010 | 08:07 AM
fly1's Avatar
83 cutlass supreme 2 door g body 455 .30 over e brock heads ported. Forged Keith black pistons 10:1 compression ratio (still want pump gas) 200r4 3.42 or 3.73 rear gears ac and power brakes trying to get in the 500 HP 600 ft lbs range
Old Dec 6, 2010 | 08:23 AM
cutlassefi's Avatar
Something like an Erson, 238/242-246 on a 110 maybe even a 112 for the p/b and a/c, lift would be .584 with 1.6 rockers but with ported Edelbrocks I'd go with 1.7's for .620 lift. A port matched Torker and an 850 ought to get you there. Bigger intakes (2.125 or 2.140) will help as well. It should make 560+ or so on the torque and 530-540 on the hp imo.
Whatever you do, get something with some lift to take advantage of the heads. Plus you'll need to keep the duration and lobe sep in check to some degree cuz of the p/b a/c.
Old Dec 6, 2010 | 08:36 AM
Run to Rund's Avatar
You want 500 HP? Try the Comp Cams 294-300 hydraulic roller, .576, .600 lift. Durations at .050" are 242, 248 deg. 108 lobe centers would be best, but if you must run vacuum accessories, you may have to widen the lobe centers, and possibly step down in duration a notch. The lobe numbers are 3317, 3318. If you are willing to "try" for 500 but settle for somewhat less, you can lower the duration figures. The lobes are listed in the back of the catalog under extreme energy. The cams in the front are more streetable but make less power.
Old Dec 7, 2010 | 10:00 AM
fly1's Avatar
Comp cams can make custom grinds i might contact them
Old Dec 7, 2010 | 01:35 PM
If the sales staff at the 800 number isn't happy to make what you want, you can "inquire within" and you will find technically astute people at Comp who believe in service, know cams, and will grind anything that makes any sense at all. Even back in the 70s, I picked the lobes and lobe center I wanted and they ground it for me. The price is reasonable too. Many of the lobe series in the back of the catalog are as aggressive as anything you can buy anywhere, and the dynamics of their stuff help drivetrain life. Sure, you can pick something like the MM solid lifter lobes that are extremely aggressive and "on the edge" even with the required .904" and bigger lifters, but if you need a tiny bit "extra" to win, Comp is there for you. They have solid lifter profiles that are close in aggressiveness to hydraulic rollers, and to earlier, smoother design solid rollers. They have roller profiles ranging from smooth and easy to extremely aggressive. They have in-house nitriding to add durability to flat tappet aggressive grinds.
No, I don't have any stock in the company, and I'm not a dealer, just a long time customer.
Old Dec 7, 2010 | 03:10 PM
cutlassefi's Avatar
I am an Erson dealer and I agree Comp is a good cam company. They're also a great marketing company, they'll tell you what you need, just ask them.
However there are other good ones out there as well, Lunati, Howard, Isky etc.
But I deal directly with 2 guys who between them have over 40 years experience. I'd like to think that can make a difference.
And yes Erson has different profiles as well.
Old Dec 7, 2010 | 03:21 PM
gearheads78's Avatar
car guy
Is Steve Tanzi still there?
Old Dec 7, 2010 | 05:51 PM
cutlassefi's Avatar
Yes he is, he runs the joint. He's forgotten more than alot of people will ever know, me included. His right hand man is Eric Bolander. Both great guys and very knowledgable.
Old Dec 8, 2010 | 02:13 PM
cutlassefi's Avatar
My last combo on here;
455
SRP Pistons, 10.75:1
C heads, 2.07/1.68, stock, filled crossovers, welded dividers
Performer Intake
830 Quick Fuel
Scorpion Roller Rockers
Erson Hyd Roller, 238/246 on a 110, .584/592 lift
1 3/4 Hedman Headers
Chinese HEI
422hp at the rear wheels at 4800rpm.
Old Dec 8, 2010 | 04:09 PM
fly1's Avatar
455
Performer Intake
830 Quick Fuel
Chinese HEI
does it run on pump gas
Old Dec 8, 2010 | 04:34 PM
cutlassefi's Avatar
Dynoed it on BP 93. You would have an advantage, better heads so you could run less compression and still make more hp. Edelbrocks are good for about 40 or so right out of the box, not including a Torker vs this Performer, another bonus.
Old Dec 8, 2010 | 05:15 PM
As another example, a friend who is on this forum built a 400 for his 66 442 restoration with a Comp 280H magnum muscle flat tappet hydraulic (230 deg. at .050", .490" lift), headers and full exhaust, 9.6:1, stock Tri Carbs. It dyno'ed at 411 HP, 470 ft-lb.
Last edited by Run to Rund; Dec 8, 2010 at 07:22 PM. Reason: corrections to specs.
Old Dec 8, 2010 | 06:37 PM
fly1's Avatar
I contacted bill at BTR and I ordered his book he told me to call him back to go over different cam specs for my application. that erson cutlassefi mention sounds pretty good
Old Dec 8, 2010 | 07:07 PM
cutlassefi's Avatar
Keep us posted if you would. I'll bet he'll recommend a Comp, maybe 234/240 or so, probably on 110 or 112 cuz of your concerns with p/b and a/c. That would sound about right.
I'd probably do about the same as my post above for you but on a 112 for better driveability, maybe change the exhaust lobe a little as well.
Jmo.
smietana
Nov 3, 2013 12:07 PM
Scott Hamel
Aug 16, 2013 07:46 AM
442garage
Aug 9, 2013 07:13 AM
rcdynamic88
Jul 18, 2013 05:01 AM
442garage
Oct 20, 2008 10:25 AM
