Choosing the right cam for 350 rocket
Old Aug 12, 2008 | 01:24 PM
70cutty's Avatar
Beer Connoisseur
Please help. I am rebuilding my 70 350 rocket and I would like to install Comp Cam 268H complete kit (Camshaft, Lifters, Timing Chain & Gears, Valve Springs, Spring Retainers, Spring Locks)
Camshaft specs:
Operating Range:1500-5500 RPMDuration Advertised:268° Intake / 268° ExhaustDuration @ .050'' Lift:218° Intake / 218° ExhaustValve Lift w/1.6 Rockers:.456'' Intake / .456'' ExhaustLobe Separation Angle:110°
Right now I have a Edelbrock Performer Intake, holley 570cfm Street Avenger, Hooker ceramic coated headers, flowmaster exhaust. I am also installing a TCI Saturday night special Torque converter.
Would this be a correct setup??????
Also does anybody know if timing chain in Comp cam's kit is a double roller or would Cloyes true double roller be a better choice???
Old Aug 12, 2008 | 02:10 PM
https://classicoldsmobile.com/forums...-hc-350-a.html
I sincerly hope you don't open up another can of worms like the above thread "fist fight"
Old Aug 12, 2008 | 02:21 PM
captjim's Avatar
Are you changing the pistons and if so which ones are you using? It might like a little more carb.
Old Aug 12, 2008 | 02:38 PM
70cutty's Avatar
Beer Connoisseur
Stock pistons. Engine has 42,000 original miles and heads were never taken off.
Old Aug 12, 2008 | 02:40 PM
70cutty's Avatar
Beer Connoisseur
I may upgrade to Street Avenger 670
Old Aug 12, 2008 | 02:45 PM
380 Racer's Avatar
I tried that 268 Comp cam when my car was still on the street. I consider it one of the worst cams for Olds out there. Personally I would go with the Cloyes set up.
Old Aug 12, 2008 | 02:55 PM
88 coupe's Avatar
Junior Member
Originally Posted by Jamesbo
........ I sincerly hope you don't open up another can of worms ........
Not a chance. This poster is open to suggestions, in all areas.
Norm
Old Aug 12, 2008 | 02:58 PM
captjim's Avatar
That cam has a lot of duration compared to lift. It is only my opinion, but I believe that cams with more lift relative to duration are better in Oldsmobiles. Crane, Engle, Lunati, Bullet, etc all are popular Olds cams. Just for comparison, the Engle 16-18 in my car has 210/216 @ .050 but with .472/.488 lift, Also, it is on a 112, not a 110. Do you (or anybody else) know the piston dish size in the stock 350 for that year?
Old Aug 12, 2008 | 03:06 PM
70cutty's Avatar
Beer Connoisseur
Diameter Nominal Outside 3.8685"
Length Overall 3.490"
Top of the piston to Center of Pin 1.738" - 1.742"
Old Aug 12, 2008 | 03:23 PM
70cutty's Avatar
Beer Connoisseur
Maybe Lunati Voodoo would be a better choice??
  • Advertised Duration (Int/Exh): 256/262
  • Duration @ .050 (Int/Exh): 213/219
  • Gross Valve Lift (Int/Exh): .485/.499
  • LSA/ICL: 112/108
  • Valve Lash (Int/Exh): Hyd/Hyd
  • RPM Range: 1000-5300
Old Aug 12, 2008 | 03:28 PM
captjim's Avatar
I am not sure of your actual compression ration, but IMO, that Voodoo would be a MUCH better choice, especially in a driver without a lot of gear. The ramps are very steep on those, so they kinda "act" smaller. You might sacrifice a little top end, but the throttle response and drivability should be better. Again, IMO. And also depending on the Cr.
Old Aug 12, 2008 | 03:47 PM
70cutty's Avatar
Beer Connoisseur
I won't know 'till I take the heads off and see the piston notches but I think it's 9.0:1
Old Aug 12, 2008 | 05:44 PM
Redog's Avatar
What do you want the car to do?
Old Aug 12, 2008 | 07:33 PM
70cutty's Avatar
Beer Connoisseur
I am rebuilding the engine so while I have it out of the car I want it to upgrade the cam and couple of other things.
Old Aug 13, 2008 | 04:46 AM
captjim's Avatar
In your rebuild are you going to hone and re-ring and keep the stock pistons are replace them? Upgrading the cam is certainly a good idea, IMO, as the stock one is quite mild. Somewhere in the 194/.400 neighborhood, IIRC. What gear is in the car and are planning on changing it, too.
Old Aug 13, 2008 | 05:48 AM
70cutty's Avatar
Beer Connoisseur
I will re-ring stock pistons. gear ratio is 2:56, after I'm done with this project I will be rebuilding rear end installing posi traction and probably go with 3:23 or 3:42 gear ratio
DYSKIE
Jan 24, 2015 07:14 AM
HitTheHole
Feb 1, 2014 12:04 PM
Oldskool84
Dec 30, 2013 03:50 PM
olds67
Jun 6, 2010 09:23 AM
1FSTLS1
Dec 20, 2008 05:45 AM
