Help choosing cam.
Old Jan 23, 2015 | 11:32 AM
DYSKIE's Avatar
Help choosing cam.
Hello, I have 68 442 with 455 cast iron E heads minor port, TH400, 4:10 rearend, car has power break.
I found two cams with same specs except lobe center is different, Which lobe center will be suitable for my engine?
Cam specs:
HYD. flat tappet 304/316.
Duration @ .050" Lift: Intake / Exhaust. 234 / 244
Valve Lift: Intake / Exhaust .520 / .542
Lobe center: 112
other cam lobe center is INT. 107/ EXH. 117
Old Jan 23, 2015 | 03:22 PM
cutlassefi's Avatar
Cam specs:
Lobe center: 112
They're the same camshaft, 117+107/2 is 112.
What is your compression? That cam will be lazy unless you have upwards of 11.0:1.
Thanks.
Old Jan 24, 2015 | 05:39 AM
DYSKIE's Avatar
Thanks.
Thank you Mark for the information I'm not expert with engines, I think compression is 10 or more I remember previouse owner told me around 10.5:1.
Old Jan 24, 2015 | 07:14 AM
cutlassefi's Avatar
Unfortunately your combo is a little off. Unless you're going to race it the 4.11 rear gear is a waste. You normally won't be turning it high enough to use it.
But now you have a high gear, which is fine with a bigger cam, but you have power brakes and your converter is unknown. You might want to verify that as well.
HitTheHole
Feb 1, 2014 12:04 PM
Al2011
Aug 24, 2011 06:58 PM
Al2011
Aug 16, 2011 08:03 AM
1FSTLS1
Dec 20, 2008 05:45 AM
70cutty
Aug 13, 2008 05:48 AM
