PDA
View Full Version : Small Blocks
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 1964 Fuel Pump
  2. Broken Dip Stick Removal
  3. rear main
  4. High oil pressure... damage??
  5. 403 with BB heads - exhaust question
  6. Yanking my 260 to make room for 350
  7. Oil pump gasket
  8. Looking for specs
  9. looking for ballpark re: power output
  10. 403 Build
  11. NASCAR blocks
  12. Blowing out exhaust gaskets
  13. Rocket 350 Rough idle in gear, mystery continues
  14. Ignition coil FULL of water
  15. Pulley System
  16. 350 diesel dx block .921 lifter !!
  17. Olds 350 Rebuild - Overheating
  18. trying to determine correct oil filler decal codes
  19. 1969 Rocket 350 random rough idle.
  20. converting a 350 rocket to tbi
  21. exhaust choke block plate leak back fire
  22. 350 rocket back fire at w.o.t
  23. New 350 with FITech system...
  24. 1972 delta 88 350 possible cam
  25. 350 Rocket "dieseling" problem
  26. I Think I'm Burning Oil
  27. Thorton manifolds on a 68 350"
  28. Cylinder Head - Paint or Raw?
  29. Is it worth the trouble?
  30. Stock.
  31. 307 floating wrist pin
  32. Hardly Running
  33. 350 rocket tune issues
  34. Sanderson headers question
  35. 1969 Rocket 350 with Late 70s GMC truck Quadrajet, cold start problem
  36. Sea Foaming a Motor
  37. 1970 Holiday Coupe 350 rebuild
  38. Running Hot
  39. What Is Even Going On?
  40. 1950 303 leakage as the norm?
  41. Under Pressure
  42. Timming marks
  43. What the heck is wrong with V belts these days?
  44. The mighty 260 finally did it in!
  45. Alt. Alignment
  46. Head gasket?
  47. PCV Grommet
  48. Aftermarket cylinder heads availability?
  49. 330 #2 heads Adjustable Rocker conversion valve cover height?
  50. Edelbrock Perfomer olds 350 Manifold
  51. 1972 350 rocket timing chain and cam change
  52. 72 350 rocket 2 barrel timing issue
  53. Coolant in 94 Ciera
  54. 1984 307 CCC Carb problems
  55. Accuracy of Equus gauges?
  56. Not able to torque head bolts
  57. Carb Rebuild- Ken at Everyday Performance
  58. Losing power after 350 warms up
  59. 305 V8 cuts out and hard to start
  60. Carb pump diacharge nozzle
  61. Rochester 2 Barr replacement
  62. '70 rocket 350 engine noise
  63. Long Crank
  64. 4.00" stroke small block crank
  65. Edelbrock 7111 on a 330 - three big problems
  66. 350 exhaust gaskets and dipstick tube questions
  67. Coolant leakage
  68. stock 350 harmonic balancer recommendations?
  69. Vaccuum lines, heater hoses, rubber fuel hoses, pcv valve hose, etc
  70. Heater hose fitting for Edelbrock 7111
  71. Idle Speed
  72. Starting issues
  73. Miss fire on 87 307 cutlass
  74. Thoughts of turning my 70 into a cruiser instead of a street/strip machine
  75. Mating th350 to olds 350 while motor is already mounted
  76. Headers and Oil Fiter
  77. 330 intake manifold
  78. Flywheel balance
  79. 3a Heads
  80. Removing header flange??
  81. Newbie with a problem.
  82. Carburetor Help
  83. Installing stock Exhaust system on my 72 Cutlass
  84. Minimum I need to run engine?
  85. Unidentified plug hanging under car
  86. Thermostat Setting On 350 w/o AC
  87. .068 over bore with BBO pistons? Same stroke?
  88. Pistons
  89. What is the torque rating for the Flexplate bolts?
  90. upgrades are like Lays Potato chips...
  91. Q-jet Carb
  92. Bolt question
  93. When I crank my car for the first time it idles high - 72 Cutlass S (350 Rocket)
  94. Pushrod selection
  95. 350 engine rebuild
  96. Another crankcase ventilation ?
  97. I need a new fuel tank sender for my 70 Cutlass S, return or not?
  98. need to get a smaller carb?
  99. Intake manifold & head gaskets
  100. 71 350 olds with edelbrock aluminium heads
  101. Cam questions
  102. PCV Valve Help
  103. Carb help
  104. Is there a gasket between the engine block and trans?
  105. Just bought a sweet 215
  106. Exhaust manifold opinions wanted
  107. Harmonic balancer install
  108. Broken exhaust manifold bolt in head
  109. Bad new radiators?
  110. Fuel Tank Install Questions
  111. Two small grooves in rear main cap
  112. 2 groove crank pulley
  113. Water pump question
  114. 1964 330
  115. Cooling system question: thermostat and radiator cap
  116. Rough Idle on 69' 350
  117. Intermittent loss of spark when hot on a Mallory Breaker less Ignition
  118. Oil pump and bolt on screen and pickup
  119. New MSD HEI
  120. Need some help What causes this?
  121. Carb Spacer 67 330 Q-jet
  122. Best place for a remanufactured engine?
  123. Gold engine paint.
  124. Intake manifold help
  125. Cam break in procedure
  126. 70 350 cam / idle question
  127. Valve cover bolt snapped- how should i extract it?
  128. Does the heat stove get a gasket?
  129. New carb setup - opinions needed
  130. Need help on SOB- SBC initial start
  131. What is wrong with keeping a 350...
  132. Hedman Hedders
  133. 44S for my 66 Cutlass 330?
  134. Neoprene rear main seal for 350
  135. fuel bowl goes dry
  136. Exhaust manifold gaskets???
  137. I noticed an Odd Behavior with the Car Today
  138. Can someone tell me if there's a reason why somebody would do this other than being
  139. Cold start kick down
  140. Timing: Can these numbers be right?!
  141. What to lube as I reassemble?
  142. What type of intake manifold gasket?
  143. Gaskets and RTV vs spray gasket adhesive vs gasket only
  144. heater control valve w/ edelbrock 7111 intake
  145. Does my timing chain need to be replaced?
  146. Cam for my Olds 350?
  147. Headers that fit a '68 S 350?
  148. Olds 260 base timing
  149. Too much
  150. '69 heads
  151. Should I put bigger valves in my #5 heads?
  152. Leaking carb
  153. 65 330 head bolts & torque?
  154. 80 98 350 hesitation/vacume leak?
  155. Aftermarket Thermostat Housing Goose neck
  156. Valve spring pressures for mild roller
  157. Push rod length?
  158. Swapping worn out 307 for a 455
  159. Replacement fan shroud too small
  160. Breaking up, popping, and even shut down... Ignition.
  161. Crankshaft key question
  162. 83 307 problems
  163. distributor bolt hole question - 350
  164. New and need a little help
  165. 1981 Toronado Belts
  166. Olds 350 Exhaust cross over port in intake
  167. Last 403 built at the factory
  168. rubber vs. cork
  169. 1973 350 timing
  170. Timing set, new problem
  171. Headers
  172. 307 Rebuild
  173. 330 heads
  174. Porting stock 350 manifolds?
  175. PCV Valve troubles
  176. Intake/ seeping oil leak
  177. 330 4v Harmonic Balancer vs. early 400/425
  178. Distributor Hold Down Bolt
  179. RPM performer hood clearance '71
  180. Mobil 1 M1-206 or Fram Ultra Synthetic 3506?
  181. I Need Help! New Waterpump on 72 S 350. Now Belts Won't Line Up
  182. Torqued off!
  183. Cooling my 70S with the 350 upgrade
  184. Fuel pump question
  185. Shimming oil pump psi spring?
  186. shaking my head
  187. New Distributor for 1970 cutlass 350, recomendations?
  188. olds 307
  189. stutter, hesitation, under load only
  190. 69 rad cap
  191. Intake Manifold - All in one posting (hopefully)
  192. What is it called???
  193. HELP!!! no fuel going to carb and im stranded!!!
  194. Cam for 1970 350 #6 heads
  195. Who wants to beat this dead horse?
  196. how do you tell what heads they are? how do you know if they need to be worked on?
  197. distributor ?
  198. Camshaft play
  199. 350 heads
  200. Lifting my 330
  201. Rebuild kit?!
  202. Rochester 4 Jet carburetor model ??
  203. Cylinder head bolt question
  204. 403 to replace 350?
  205. Gasket for oil pressure sending switch
  206. Tick tick tick
  207. overbore only DX SBO Olds build
  208. Who rebuilds CCC quadrajets?
  209. carb help 725 demon road master
  210. Cam timing
  211. What's that sound?
  212. two piece intake gasket vs. Valley pan intake gasket
  213. motor building advice
  214. Engine dies when put it in drive
  215. Pushrod geometry question...
  216. Flow Numbers
  217. Quadrajet problems
  218. wood spacers vs. aluminum spacers
  219. Help ID these please
  220. valve cover Breather size?
  221. Which pistons 14cc / 23cc ?
  222. Rocket 324 troubles
  223. Hard start after sitting for 2 weeks or more...
  224. Thinking about a new carb!
  225. edelbrock carb problems
  226. Engine turns over slowly
  227. intake help
  228. 1971 #7 Head Valve Spring Pad & Rotator Question
  229. Carburetor Help
  230. Fuel pump variation - glass bowl vs all metal housing
  231. Another Head Question
  232. 3a heads vs 7a heads
  233. Lower radiator hose rubbing - '72 Cutlass
  234. 67 330 intake gaskets
  235. Pictures of engine and engine bay
  236. Help with rocker studs
  237. best rearend gears to replace my stock gears
  238. Smell of Gas under Medium/Hard Acceleration
  239. 71 350 rebuild help needed
  240. Share your 350 rocket exhaust experiences
  241. 65 Cutlass + exhaust manifold ?
  242. Removing 350
  243. HEI Ignition
  244. looking for air cleaner options/ pictures of setups.
  245. What is a 1972 running 350 rocket with 47,000 original miles worth
  246. 350 intake gasket
  247. Why in the hell are certain parts restricted?
  248. Rocker Arm Studs
  249. Timing Recurve Kit Question - Hopefully before sundown
  250. EFI or Q-Jet?
