3a Heads
Old Sep 7, 2016 | 08:03 PM
cus's Avatar
cus
3a Heads
Just had some 3a Heads reconditioned, they are going on a 1973 block,
the head bolt size for the 3a heads is 1/2 inch, the bolts for the '73 block
are 7/16, he said there is no need to sleeve the head bolt holes , they will
locate on the dowells, I'm a bit suspect on this, any advice appreciated,
regards, cus
Old Sep 7, 2016 | 09:17 PM
gs72's Avatar
72Cutlass S
He is right. The dowel pins locate the head. The bolts just clamp it to the deck.
Old Sep 7, 2016 | 10:51 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have done the same thing with 5A heads on a 76 350. For one, the 1/2" to 7/16" head bolt bushings are to small for factory head bolt holes. I know because I tried them. I ended not using them, first set of head gaskets lasted 5+ years, one blew. Replaced the gaskets and drove till it burned You will have to go a hair over 1/2" for the bushings, my #6 heads that were put on a 403, the bushings fit fine and I used them. I hope those 3A heads were checked for cracks.
Old Sep 7, 2016 | 11:21 PM
cus's Avatar
cus
Thanks for the replies,
Yes, they were crack tested
Old Sep 14, 2016 | 08:56 PM
brownbomber77's Avatar
17/32 is the drill bit. I usePro Comp bushings and they worked fine with the holes I had drilled on a set of #7 heads that ended up going back on an early engine.
Old Sep 15, 2016 | 04:58 AM
cus's Avatar
cus
Also, a bit confused on bolt torque, have torqued to 85ft lbs, but just read that later heads should be 130 lbs , that's. Big difference, seems excessive with 7/16 bolts.
Old Sep 15, 2016 | 06:40 AM
Later motors used 1/2" bolts so 130 ft/lbs is the spec. Only torque them to 85 ft/lbs.
Old Sep 15, 2016 | 02:43 PM
cus's Avatar
cus
Thanks, thought was the case.
Maybe that's why there were so many crack issues on later type heads, 130lbs is really
clamping them down!! not much room for expansion etc.
Old Sep 16, 2016 | 06:20 AM
edzolz's Avatar
I would use hardened washers under the bolt heads to distribute the load better.
Old Sep 16, 2016 | 12:21 PM
Hardened is the key word. I tried that with my 5A heads on a 76 block with regular washers, broke a head bolt. Just ran without but hardened should help.
Old Sep 16, 2016 | 05:46 PM
cus's Avatar
cus
That's a good idea, but too late for know...all bolted down!
Just noticed 3A heads don't have as many bolts in the rocker box covers,
my covers will still fit but will have some boltless holes, not sure why they did that,
did the 3A's have a thicker gauge cover or something, not requiring so many bolts?
Old Sep 17, 2016 | 06:05 AM
The later engines they saved weight and cost. Ten bolts per engine when thousands are being made adds up. Just use RTV in the holes, just a dab.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
