3a Heads
Old September 7th, 2016, 08:03 PM
cus
cus's Avatar
3a Heads
Just had some 3a Heads reconditioned, they are going on a 1973 block,
the head bolt size for the 3a heads is 1/2 inch, the bolts for the '73 block
are 7/16, he said there is no need to sleeve the head bolt holes , they will
locate on the dowells, I'm a bit suspect on this, any advice appreciated,
regards, cus
cus is offline
Old September 7th, 2016, 09:17 PM
72Cutlass S
gs72's Avatar
He is right. The dowel pins locate the head. The bolts just clamp it to the deck.
gs72 is offline
Old September 7th, 2016, 10:51 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I have done the same thing with 5A heads on a 76 350. For one, the 1/2" to 7/16" head bolt bushings are to small for factory head bolt holes. I know because I tried them. I ended not using them, first set of head gaskets lasted 5+ years, one blew. Replaced the gaskets and drove till it burned You will have to go a hair over 1/2" for the bushings, my #6 heads that were put on a 403, the bushings fit fine and I used them. I hope those 3A heads were checked for cracks.
olds 307 and 403 is offline
Old September 7th, 2016, 11:21 PM
cus
cus's Avatar
Thanks for the replies,
Yes, they were crack tested
cus is offline
Old September 14th, 2016, 08:56 PM
brownbomber77's Avatar
17/32 is the drill bit. I usePro Comp bushings and they worked fine with the holes I had drilled on a set of #7 heads that ended up going back on an early engine.
brownbomber77 is offline
Old September 15th, 2016, 04:58 AM
cus
cus's Avatar
Also, a bit confused on bolt torque, have torqued to 85ft lbs, but just read that later heads should be 130 lbs , that's. Big difference, seems excessive with 7/16 bolts.
cus is offline
Old September 15th, 2016, 06:40 AM
Later motors used 1/2" bolts so 130 ft/lbs is the spec. Only torque them to 85 ft/lbs.
Old September 15th, 2016, 02:43 PM
cus
cus's Avatar
Thanks, thought was the case.
Maybe that's why there were so many crack issues on later type heads, 130lbs is really
clamping them down!! not much room for expansion etc.
cus is offline
Old September 16th, 2016, 06:20 AM
edzolz's Avatar
I would use hardened washers under the bolt heads to distribute the load better.
edzolz is offline
Old September 16th, 2016, 12:21 PM
Hardened is the key word. I tried that with my 5A heads on a 76 block with regular washers, broke a head bolt. Just ran without but hardened should help.
Old September 16th, 2016, 05:46 PM
cus
cus's Avatar
That's a good idea, but too late for know...all bolted down!
Just noticed 3A heads don't have as many bolts in the rocker box covers,
my covers will still fit but will have some boltless holes, not sure why they did that,
did the 3A's have a thicker gauge cover or something, not requiring so many bolts?
cus is offline
Old September 17th, 2016, 06:05 AM
The later engines they saved weight and cost. Ten bolts per engine when thousands are being made adds up. Just use RTV in the holes, just a dab.
64 CUTLASS KEN
December 7th, 2020 06:43 AM
olds4life
December 25th, 2012 12:56 AM
Oldsmaniac
November 1st, 2010 06:37 PM
gearheads78
November 10th, 2009 09:31 PM
DarkStar
October 21st, 2009 07:35 AM
Quick Reply: 3a Heads
