Cam timing
Cam timing
I got a delivery from Howards cams. Was a bit disappointed, because they did not send a proper cam card like Comp and Lunati does. Need to do the timing only according to knowledge, that intake centerline should occour 106° from TDC. Not as much information as I would like to have.
Did some degreeing yesterday, and found out intake centerline was 110° after TDC when assembled to zero key. I will try the advanced key tonight. Timing set is cloyes +-4°, so it should set right.
http://www.summitracing.com/int/part...ake/oldsmobile
0, 4°retarded and 4°advanced. Seems there is a mis-match of 4 degrees between Howards and Cloyes.
I asked a cam card and they soon replied(quick respond, credits for that) with following. I undestand this cam is intended to be assembled intake centerline 106° ATDC? To get it that way, for some reason I have to assemble the Cloyes timing set to 4° advanced position.
P/N 514245-10 VALVE LIFT INT. ,5173 GRIND HYD RLR VALVE LIFT EXH. ,5120 ENG OLDS V-8 INT OPEN 29,5 ROCKER RATIO INT. 1,6 INT CLOSE 61,5 ROCKER RATIO EXH. 1,6 EXH OPEN 74,5 CAM LIFT INT. ,3233 EXH CLOSE 26,5 CAM LIFT EXH. ,3200 OVERLAP 56 L/C 110 INT PHASE 106 ADV OR RETARD 4 ANGLE or LC INT. DUR 271 EXH. DUR 281 EXH PHASE 114 INT. DUR @ .050 219 ANGLE or LC EXH. DUR @ .050 229 INT O @ .050 3,5 4&7 SWAP INT C @ .050 35,5 CUSTOMER EXH O @ .050 48,5 EXH C @ .050 0,5 LASH .000" OVERLAP @ .050 4
Don't even think about what the timing gears say - degree it to a 106* centerline by matching up events on the cam card and call it a day. It sounds like you are already there.
The advance/retard marks on cam gear sets are not to be trusted, always checked. I have had to drill cam gears in the past and use offset bushings to degree cams. Not sure who else has them but I think I've gotten mine from Dick Miller Racing. They require a 1/2" hole in the cam gear and I think come in a set of 5.
[QUOTE=Rick Finsta;924548]Don't even think about what the timing gears say - degree it to a 106* centerline by matching up events on the cam card and call it a day. It sounds like you are already there.
That's exactly my plan. Really seems that there's no reason to trust the marks. Cheking/degreeing is a must!
