Timing chain cover / Cam
Old Sep 13, 2011 | 03:59 PM
zodiacblueS's Avatar
Question Timing chain cover / Cam
This is my first rebuild. Is the timing chain cover the only thing that holds the cam in? When I pulled the cover off there was a slight wear mark where the cam bolt was rubbing. No indent, but it seems there should be a bushing on the cam bolt end? If thats the way it's designed, its fine with me. I know the roller chain and balancer and water pump should cinch it in, but am I missing something?? Thanks for your time.
Old Sep 13, 2011 | 04:06 PM
Oldsmaniac's Avatar
The end of the bolt acts like a bushing....the chain and gears keeps it from walking too much. On disassembly the lifter will not let the cam slide out so they need to be removed for that.
Old Sep 13, 2011 | 04:07 PM
Oldsmaniac's Avatar
The distributer gear also helps lock the cam down....
Old Sep 13, 2011 | 05:14 PM
Excellent!
Thank you Maniac. I'll have more questions tomorrow.
Old Sep 15, 2011 | 09:31 AM
Not "helps", the helical angle and rotation direction of the distributor gear ABSOLUTELY pulls the cam back into the block. That's why there's a flange on the end of the cam that rides on the front face of the block. There is some "bounce" in the gears that lets the cam bounce back and forth, thus the wear marks, but the predominant load is backwards.
Old Sep 15, 2011 | 10:04 AM
Oldsmaniac's Avatar
Thank you for firming that up.
Old Sep 15, 2011 | 06:28 PM
Thank you gentlemen.
Old Sep 15, 2011 | 09:42 PM
rsandhoff's Avatar
I'm certainly no expert and I have only built one OLDS engine ( 69 400) but here is what I found. The stock cam bolt has a protruded head, slightly smaller and round, from the area where the wrench goes. This protruded area is what hits the timing cover slightly and keeps the cam from moving back and forth very much. As stated earlier, the basic design pulls the cam backward. I am adding to this post because there is a different cam bolt that has a thrust button built into it in the area that hits the timing cover. I'm not saying these are better, just another option. The thrust button acts as a buffer between the cam and the cover. It also spins on the end of the bolt itself. Mondello and others sell this bolt.
Stevec
Feb 8, 2015 01:25 PM
Freddy B
Sep 3, 2014 08:26 AM
fv64olds98
Jan 31, 2013 02:56 PM
crazy'boutOlds
Aug 6, 2009 05:40 AM
sklbndt
Apr 15, 2009 04:34 PM
