Cam gear and Timing Chain - Advice needed
Old Jan 30, 2013 | 10:42 AM
fv64olds98's Avatar
Hello All,
I have an olds 1964 98 with the 394 Sky Rocket engine. I bought a new timing chain and installed it. It thas the exact same number of links as the original. However, the part of the links that goes into the cam gear tooths is not as long so it does not seat all the way into the tooths of the cam gear as the original chain did.
Has anyone changed the timing chain on a 394? I am a bit concerned that this could lead to potentially jumping a tooth or even damaging the plastic tooths on the cam gear?
Any suggestions would help.
I did not buy a new cam gear, as the original looks good, but maybe i should buy a new cam gear with metal tooth.
Old Jan 30, 2013 | 10:56 AM
boese1978's Avatar
"but maybe i should buy a new cam gear with metal tooth."
Always!!
Old Jan 30, 2013 | 12:33 PM
m371961's Avatar
I never replace a chain without replacing gears. Always replace nylon capped gears with steel. For performance, double row chains and gears.
Old Jan 30, 2013 | 02:51 PM
Run to Rund's Avatar
I chose a Cloyes true roller chain and gears, but that was 40 + years ago; look for something similar today. Ross Racing in Ohio may be able to help if you can't find them at the usual places.
Old Jan 31, 2013 | 11:19 AM
fv64olds98's Avatar
Hi All,
Thanks for the advice, have gone ahead and orders a 3 piece set 2 gears and chain. Makes sense to replace all. Should have asked before i ordered just the chain.
Old Jan 31, 2013 | 01:45 PM
m371961's Avatar
Assuming you are installing new front seal. If you use the balancer sleeve and have never done it before, you may want to ask for suggestions to install it.
Old Jan 31, 2013 | 01:51 PM
fv64olds98's Avatar
Hello m371961,
Sorry I am not sure what do you mean by sleeve? I am planning to replace the front timing cover Crankshaft pulley seal. Could you exaplin what is meant by sleeve and why would i use one? If I do need one, is there any tips or tricks on installing it?
Thanks for all your help
Old Jan 31, 2013 | 01:59 PM
don71's Avatar
same but different
He might be refering to a "speedy sleeve" commonly used to cover up the groove that timing chain seals often wear into crankshafts. Helps to control oil leaks, very common to use one.
Check out this recent thread...https://classicoldsmobile.com/forums...ve-n-seal.html
Old Jan 31, 2013 | 02:56 PM
m371961's Avatar
Good instruction here. http://www.skf.com/binary/12-61918/TT08_021.pdf.
Page 2 shows sleeve on dampner nose. The only thing I do different is that I chill the dampner, put sleeve on a lightbulb to get hot then install.
Stevec
Feb 8, 2015 01:25 PM
Freddy B
Sep 3, 2014 08:26 AM
jerseyjoe
Nov 11, 2011 04:07 PM
henryk8398
Mar 5, 2010 09:38 AM
smcurro
Feb 27, 2009 09:27 AM
