Timing chain crankshaft gear
Old February 26th, 2009, 07:08 PM
smcurro's Avatar
Hi
What is the easiest way to remove the old timing gear from the crankshaft and install a new one? Can the gear be changed without removing the crankshaft from the engine? Is it ever possible to reuse the timing gear on the crankshaft or must this gear be changed whenever the timing chain is changed? Any info would be greatly appreciated. Thanks!!
smcurro is offline
Old February 26th, 2009, 07:37 PM
Originally Posted by smcurro
Hi
Well, the first thing is that the key needs to be removed from the keyway in the crank before the crank gear will come out. That might be enough by itself, but if not, you'll need to use a puller. Temporarily reinstall the balancer bolt to preclude messing up the threads in the nose of the crank when using the puller.
joe_padavano is offline
Old February 26th, 2009, 08:26 PM
smcurro's Avatar
Okay, I assume the key continues into the timing gear to prevent the gear from possibly spinning. How is the key removed? Is there a specific type of puller for this job? Thanks!
smcurro is offline
Old February 27th, 2009, 02:05 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I use a pair of pliers on the key. Wiggle it forward and up, and don't bend it.
The gear should come right off of the snout with the key removed.
J-(Chicago) is offline
Old February 27th, 2009, 09:27 AM
smcurro's Avatar
ok I will try that. I assume its important to very careful... Thanks!
smcurro is offline
fv64olds98
January 31st, 2013 02:56 PM
jerseyjoe
November 11th, 2011 04:07 PM
442scotty
May 13th, 2009 05:42 PM
Mr. King
March 25th, 2007 12:33 PM
olds87
May 24th, 2006 08:30 PM
Quick Reply: Timing chain crankshaft gear
