Carb Spacer 67 330 Q-jet
I had my quadrajet linkage (actually the whole rod) changed to accept the detent cable after converting to the TH 350 trans Problem is, the linkage, which is from a 69 or later, now contacts the intake manifold (stock). I need a 3/4 to 1 " spacer to lift the carb up so as to not hit the manifold. Can't find what I need. Says not to use the 4 holed unit with the heat crossovers. Do they make such a thing nor do I need to go with an aftermarket intake? Thanks
Here is an open unit:
https://www.summitracing.com/parts/trd-2109/overview/
Here is a link to the summit page for a lot of spacers if you'd like to choose something different. I prefer a 4 hole.
https://www.summitracing.com/search/...rder=Ascending
