Coolant leakage
Old Sep 20, 2016 | 11:50 AM
Copper Nine Eight's Avatar
Coolant leakage
So I just saw coolant leaking from my 307. It looks like it's leaking from the passenger side of the engine. What could be the problem?! Thanks. 1985 delta 88 307
Old Sep 20, 2016 | 11:52 AM
Passenger side front or rear? Normally its a hose problem, loose clamp, water pump, etc.
Old Sep 20, 2016 | 11:55 AM
It's looks like it coming from the front.
Old Sep 20, 2016 | 11:59 AM
Check the weep hole at the bottom of the water pump, hoses, and clamps. Follow the leak upstream to the source. Inspect the radiator and overflow tank.
Old Sep 20, 2016 | 12:04 PM
Will do! As soon as it cools down outside. 100 degrees!!!!
Old Sep 20, 2016 | 12:35 PM
A leak from the passenger side rear of a 307 is almost always caused by the heater control valve that screws into the intake at that right rear corner.
Old Sep 20, 2016 | 02:39 PM
BlackGold's Avatar
In addition to the weep hole of the water pump and the heater control valve, check for seepage at all four corners where the intake manifold meets the heads. Two of the three 307s I've owned have needed a new intake manifold gasket at around 100,000 miles. The old gaskets looked like swiss cheese. And not the good cave-aged gruyere, either.
Old Sep 21, 2016 | 06:44 AM
Professur's Avatar
How big a leak? I've had good luck with that UV dye and a black lamp. Shows the leak even on the dirtiest engine.
Old Sep 21, 2016 | 07:48 AM
Don't make this any harder than it is. Simply feel around on the underside of the diaphragm of the heater control valve and I bet you'll find coolant leaking.
Greg Rogers
Jun 30, 2014 10:16 PM
sixtyfour
Mar 26, 2014 06:00 AM
Texas Jim
Ninety-Eight
Oct 21, 2009 06:07 PM
155thINF
Aug 25, 2006 05:30 PM
72RocketPower
Nov 22, 2004 02:02 PM
