Timing set, new problem
Old Jul 1, 2016 | 06:16 PM
Redog's Avatar
Everything is new, battery needs to be replaced
Okay the 330 in my delta, I got the timing set at 7.5* BTDC. idles great, put it in gear, slowly stumbles and dies. Restarts, then the rpms slowly rise to 2500 rpms. Reset idle back to 1100 in park, put in gear, stumbles and dies.
Any ideas? I'm lost
Old Jul 1, 2016 | 06:18 PM
Redog's Avatar
Also, at idle, if I floor it, it slowly climbs in rpms, very slowly
Old Jul 1, 2016 | 07:17 PM
Does it still have points?
Old Jul 1, 2016 | 10:45 PM
svnt442's Avatar
I'm leaning towards a vacuum leak.
Old Jul 2, 2016 | 02:05 AM
Redog's Avatar
No. HEI
I read that, but it has to be a big leak, like PVC valve or brake line leak. I'll look again, but they looked fine to me.
I was also thinking fuel mixture. But I want to check everything before I start messing with that.
If it helps, when I was timing it, I mixed up cyl 3 and 6, like I always do. Firing order is correct now.
Old Jul 2, 2016 | 02:10 AM
svnt442's Avatar
18436572 counter clockwise.
Old Jul 2, 2016 | 04:39 AM
You need more initial timing for a stock Hei. Set it to 16-18* btdc with vacuum advance disconnected.
Old Jul 2, 2016 | 04:41 AM
Redog's Avatar
Yeah I had it at 18463572, but it's correct now with the 18436572.
Weird, the engine shook a little, but no popping thru the exhaust.
Old Jul 2, 2016 | 04:42 AM
Redog's Avatar
Really? Even with a 1967 330?
My other one had a 1968 350, so that was set to 20.
Old Jul 2, 2016 | 04:45 AM
Yes, there is less mechanical advance built into an HEI vs a points distributor.
Old Jul 2, 2016 | 04:51 AM
svnt442's Avatar
I missed that. Yes, an HEI requires more initial due to the way that the advance curve is set up from the factory. You can buy a re-curve kit to give it the same type of curve that the points distributor had if you feel the need to.
Old Jul 2, 2016 | 08:01 AM
Redog's Avatar
Makes sense. At one point I had it at 19* and it ran pretty good, except the 3 and 6 plugs mixed up.
Don't know why that throws me off so much
So what would total timing look like then? 32*, 34*, 36*?
olds 307 and 403's Avatar
Out of Line, Everytime😉
You will find it runs massively better with more timing. I have seen some HEI's with a less agressive curve, needing 12 or 13 base to hit 36-38 total. Run as much part throttle timing as possible with out pinging on the Olds V8. What is the actual compression ratio?
Old Jul 2, 2016 | 08:03 AM
Redog's Avatar
Sounds good
Thanks a lot guys! I'll post my results. Going to be "Kenny's Garage" tomorrow
Old Jul 2, 2016 | 11:06 AM
Figure what total timing works best, leave the vacuum advance disconnected. Once you get your total dialed in then work on limiting the total with vacuum advance to 50-52.
Old Jul 2, 2016 | 11:45 AM
svnt442's Avatar
If you don't know how much the vacuum can advances the timing, get a vacuum pump, hook it up to the distributor and watch the timing mark as you pump it. Then once you know your total mechanical you can just add that to your vacuum number and you have your total advance number. That will only come into play at light throttle while cruising on the freeway....usually.
Old Jul 2, 2016 | 05:33 PM
I find 38 feels better on the street, 36 at the track.
Old Jul 3, 2016 | 01:37 PM
Redog's Avatar
Okay, got the initial timing to 19. Good idle but that's about it.
Engine races to 2100 rpm, tap the gas and it settles down (pinging at 19 too)
I put it in gear, stumbles down, dies. Restart the car, the same thing!
Wan to pull my hair out here!!
Old Jul 3, 2016 | 02:03 PM
What carb? Stock HEI? I would try running it with the vacuum advanced unplugged and the hose plugged. You may need an adjustable vacuum advance, what is your 330's compression ratio?
Old Jul 3, 2016 | 02:09 PM
Redog's Avatar
Edelbrock 600 CFM, stock HEI . Vacuum advanced was unplugged.
The motor has a 10.25:1 CR.
It is backfiring thru the carb. Not too bad, popping and I see a drop or two of gas shoot out. Did the flame thing yesterday.
Battery is charging right now, it's dead. Other than rolling up the window, I'm done for the day
Old Jul 3, 2016 | 03:08 PM
The Edelbrock carb opens a can of worms, is it a known good carb? Mine popped out the exhaust.
Old Jul 3, 2016 | 03:10 PM
Redog's Avatar
It is brand new
Old Jul 3, 2016 | 03:27 PM
Check to make sure your mechanical advance is not sticking, lube it up. Edelbrock carbs have had a lot of issues right out of the box over the years. It sounds like yours may be lean.
Old Jul 3, 2016 | 04:16 PM
Redog's Avatar
Ok how do I check?
Old Jul 3, 2016 | 04:17 PM
Is it a consistent popping like a rapid fire machine gun? Is the choke linkage stuck keeping the idle up? Can you adjust the idle down?
Old Jul 3, 2016 | 04:28 PM
Redog's Avatar
Yes, the ideal can be adjusted no problem. It's not a constant popping, when it stalls and I try to restart, it does it, but not all the time
Old Jul 3, 2016 | 04:34 PM
As long as it moves freely and someone didn't throw on really light springs it should be fine. Is the starter dragging on restart?
Old Jul 3, 2016 | 04:39 PM
Redog's Avatar
It is, because the battery needs to be replaced
The popping can be a few things, high idle with a lot of fuel flowing and then the engine turns off, raw gas in the manifold. Are you sure your wires are right?
If the idle drops down when you tap the accelerator its the choke causing it.
Lower your timing and leave the vacuum advance disconnected until you get your initial and mechanical set.
Old Jul 3, 2016 | 04:41 PM
Redog's Avatar
Okay, I will. Tomorrow I do need to pick up a new battery for it. Battery is 5 years old
Old Jul 3, 2016 | 04:44 PM
  #31
Redog's Avatar
I have an electric fuel pump in the car too. It's just a basic pump. It ticks when the key is turned on
Old Jul 3, 2016 | 04:47 PM
  #32
Edelbrock carbs are extremely sensitive to high fuel pressures. Make sure its 6#'s or less.
Old Jul 3, 2016 | 04:53 PM
  #33
Redog's Avatar
I'm sure it is. I didn't install it though.
Old Jul 3, 2016 | 09:47 PM
  #34
svnt442's Avatar
This might sound REALLY stupid, but I have seen it before soo....
Check the rear of the carb and make sure that there is either a vacuum fitting with a hose on it or a plug there. That will cause a rather larger vacuum leak if neither is present.
Old Jul 4, 2016 | 09:09 AM
  #35
Redog's Avatar
Yeah I checked that. My brake booster is threaded into it just just if the quardrajett was still there
Old Jul 4, 2016 | 05:15 PM
  #36
Redog's Avatar
Thinking about this,
I do have the 330 timing marker, but I'm wondering if I do not have a correct 1967 balancer on there. What are the differences in the timing marks?
Old Jul 4, 2016 | 08:13 PM
  #37
svnt442's Avatar
The only one that you have to worry about is the 1964 330. As far as I know all others are the same. (Joe P?)
Old Jul 4, 2016 | 10:06 PM
  #38
The early balancers are different from the 68 and later balancers. They look different, take a picture. You have high compression, I have a feeling 19 is too much and that carb is probably needing adjustment.
Old Jul 4, 2016 | 11:55 PM
  #39
svnt442's Avatar
The early balancers are different from the 68 and later balancers. They look different, take a picture. You have high compression, I have a feeling 19 is too much and that carb is probably needs adjustment.
But the timing mark is still at the same point on the balancer.
Old Jul 5, 2016 | 02:35 AM
  #40
Redog's Avatar
seemed to work well at 23, until it stumbled and stalled. Restart, put it in gear, and it stalled again.
Had to use the Volvo to push it back in the driveway
