Timing set, new problem
Old Jul 5, 2016 | 03:24 AM
  #41
svnt442's Avatar
Man that sure sounds like a vacuum leak to me.
Old Jul 5, 2016 | 05:59 AM
  #42
olds 307 and 403's Avatar
Out of Line, Everytime😉
If the timing is close and carb is working properly, it will drive without stalling, just might not be ideal. I remember J&S machine having an issue running an early balancer and a late timing pointer. I believe it read a few degrees more than it actually was. He was testing the new chamber on the Edelbrock heads and didn't make sense a better chamber liked 40 degrees. Have you tried driving with and without the vacuum advanced hooked up? Spray some carb cleaner around the base of the carb. Which intake and any adapters used? Unfortunately that Edelbrock carb may be the issue. I would have bought the Street Demon 625 or a Quickfuel 600 cfm for a 330 over the Edelbrock carb, just too many past issues.
Old Jul 5, 2016 | 07:16 AM
  #43
Redog's Avatar
I'm not sure if the balancer is correct or not. It was just a theory
A lot of people, on here and IRL are also saying "carb" so I'm thinking of swapping the quardrajett from the 307 onto this motor.
The entire time I had the car with the 307 in it, this carb was not hooked up to the computer at all. Car ran great with this carb, ran consistent low 18's all day long in the 1/4 mile. Even turned a few high 17's after the ring and pinon swap. Plus the edlebrock carb is a manual choke. I never mentioned it because I didn't think it was an issue until my coworker told me it was and causes hard starts
Old Jul 5, 2016 | 07:20 AM
  #44
No choke will make it run rough at idle until it warms, but it should start with no issues on a warm day and wired open. What is your vacuum gauge reading, is it steady?
Old Jul 5, 2016 | 08:25 AM
  #45
Redog's Avatar
I don't have a vacuum gauge
I'm not really going to have time to mess with it today, but hopefully tomorrow after work, I'll be able to spare an hour or so.
Old Jul 5, 2016 | 08:26 AM
  #46
Redog's Avatar
And I can'rt drive the car. I put it in gear, it stumbles and dies.
twice, Ive had to use the Volvo to push in back in the driveway
Old Jul 5, 2016 | 09:05 AM
  #47
Redog's Avatar
I'm siting here are work and I'm trying to think of the intake manifold and wondering if there is a plug missing in one of the runners or something. I really didn't look, but it's worth taking a closer look at
Old Jul 5, 2016 | 09:49 AM
  #48
svnt442's Avatar
Have you tried closing the choke at all to see if it will stay running in gear? I didn't realize that it was a manual choke.
BTW I don't understand all of the Edelbrock carb bashing. I ran one for years on my 455 with 0 issues. Right out of the box. The car started the first time, every time. Never stumbled, never backfired on me....nothing like that.
Old Jul 5, 2016 | 04:26 PM
  #49
1BOSS83's Avatar
What years? I've also had issues with that carb.
OP, is it a 1405 or 1406? 1406 is electric choke. What is your idle RPM set at and have you adjusted the idle screws at all? If you're running too lean the lead put on the car when you put it in gear will kill it.
Old Jul 5, 2016 | 05:37 PM
  #50
Redog's Avatar
Yeah, I was talking to my coworker today (raced sprint cars for 20-30 years) and he asked about the choke. I told him it was a manual choke and he was asking if there was a spring on the side to close it. Then it hit me, it's not a choke I'm used to. D'oh
It's a 1405 carb. When I bought it, I didn't realize it was going to be such a pain (manual choke) I just thought it meant it wasn't electric like on the 1406 like I had in the past.
I've been adjusting the crap out of the idle screw. When it races, I turn it down, when it stumbles, I turn it up. Still falls on its face.
Tomorrow after work, I'm going to look closely at the runners, look for any missing plugs, etc
Old Jul 5, 2016 | 10:37 PM
  #51
Without a choke you may need a richer mixture, try adjusting the idle mixture screws out. It may need smaller primary rods as well. If you let it warm up for a while, does it run better?
Old Jul 6, 2016 | 05:44 AM
  #52
It has a choke, it needs a cable installed to make it operate. Why would you adjust the idle mixture screws or change jets for a warm up function? The carb needs to be adjusted for the best idle after the engine is warmed.
Old Jul 6, 2016 | 06:26 AM
  #53
Because, I am betting it is lean. First off buy an automatic choke or maybe give the Qjet a try. You know the Qjet worked fine on your 307. My car starts and runs fine in nice weather without a choke plate. Cliff Ruggle builds a lot of Qjets without choke plate installed but leaves the coil and fast idle in place. Mine is the same and works well in decent weather.
Old Jul 6, 2016 | 09:40 AM
  #54
Redog's Avatar
When it warms up, it idles rough and fast then it stalls. I tend to agree that sounds like a lean condition.
Today when I get home from work I'm going to work on it for a little bit.
I'm going to close the choke and check for what could lead to a vacuum leak (like a missing plug or something in the manifold) I'm going to disconnect and plug up the vacuum advance then start the car and see what happens.
How many turns and of which screw should I go? This is the last time I'm trying this. If it doesn't work out, I'm making time to throw the Qjett back on
Old Jul 6, 2016 | 10:00 AM
  #55
svnt442's Avatar
If you find no obvious leaks, pull the hose from the brake booster and plug it....just to see. You never know.
Old Jul 6, 2016 | 12:40 PM
  #56
Redog's Avatar
^^ Will do
Old Jul 6, 2016 | 01:59 PM
  #57
Redog's Avatar
Okay, runs pretty good, until warmed up again
Plugged all noticeable vacuum ports. No known leaks. Vacuum advance is off distrubtor and plugged.
Choke opens as soon as car it started. Manually close choke, car stalls instantly. Starts good after pumping gas pedal. (Typical starting for Oldsmobile in my experience)
Played with the mixture screws, car was starting to stumble, opened them up, still stumbled, still stalled. Restarts no problem, stalls less than 3 minutes later.
Put in gear, idle drops to 550, then to 500, then stalls out, but took longer to do this today. Took 30 seconds on Sunday to stall, today it took 1.5 minutes.
New timing light broke, it's a POS. Have to shop for a new one. Probably will pick up a Snap on off eBay
Car really reeks of gas, will restart right after a stall. Smells flooded, but I don't think it is.
Ideas?
  #58
Redog's Avatar
I took some videos too
Old Jul 6, 2016 | 02:13 PM
  #59
Redog's Avatar
Here are some vids
http://https://youtu.be/B4DYY_jZFXU
http://https://youtu.be/7UOmKKGoez8
Old Jul 6, 2016 | 02:23 PM
  #60
svnt442's Avatar
Those links don't work
Old Jul 6, 2016 | 03:11 PM
  #61
Redog's Avatar
Try these, copy and paste
Old Jul 6, 2016 | 03:33 PM
  #62
svnt442's Avatar
Do you have one of these on the manifold?
Old Jul 6, 2016 | 03:47 PM
  #63
My next question was along the same line, what intake is installed?
Old Jul 6, 2016 | 03:48 PM
  #64
svnt442's Avatar
That is a Performer RPM.
Old Jul 6, 2016 | 03:56 PM
  #65
Then it should not require an adapter. With your vacuum lines disconnected and the idle set at 650 in park, what is your initial timing? Have you hooked up a vacuum gauge to see what it is and is the needle steady? What is your spark plug gap?
Old Jul 6, 2016 | 04:29 PM
  #66
svnt442's Avatar
It still has a spread bore pattern so it needs it.
Old Jul 6, 2016 | 04:32 PM
  #67
svnt442's Avatar
Interesting.....Edelbrock says it doesn't need the plate. I was unaware of that. I still couldn't bring myself to bolt one on without that plate with the flange being as thin as it is in spots.
Old Jul 6, 2016 | 04:41 PM
  #68
Edited, You beat me to it!
From the Edelbrock website:
Quote - OLDSMOBILE 307-403 V8
PERFORMER RPM OLDS 350 (1500-6500 RPM)
Designed for 330-350-403 c.i.d. Oldsmobiles and 1980-1/2 to 1985 307 c.i.d. engines with 5A heads (casting #3317). The Performer RPM Olds intake manifold is a high-rise, dual-plane design with 180° firing order engineered for maximum top-end horsepower while maintaining throttle response. Port flange has extra material above the runner for use with cast iron 455 heads and Edelbrock Performer RPM heads #60519. Has clearance for HEI distributor. Carb pad accepts square-bore carbs without adapters
http://www.edelbrock.com/automotive/...r-rpm-sb.shtml
Old Jul 6, 2016 | 04:51 PM
  #69
svnt442's Avatar
I research....lol.
Old Jul 17, 2016 | 11:24 AM
  #70
Redog's Avatar
Okay. Here's an update.
I took the edlebrock carb off, put the quadrajet back on. Bolted right on
Also installed an inline fuel Pressure gauge.
All 3/8 inch lines. Here's what I found.
  1. Fuel pressure is between 9 and 10 psi, needle bounces radically between 9 and 10
  2. No provision for the tubes for the choke on the vacuum, so I converted it to electric choke. I did hook up the vacuum lines to the choke stuff. Didn't know if I should or not
I didn't see anything on the fuel pump to adjust the pressure, could be inside the fuel line, but I'm not sure. Fuel pump run when the key is turned on, and runs runs runs. What is the max pressure for the Quadrajett?
Electric choke is NOT hooked up. It just needs a 12 volt source switched of course. Could I splice it into on of the old emissions lines that's not being used anymore? Going to cut all the lines out anyway
Old Jul 17, 2016 | 11:25 AM
  #71
Redog's Avatar
This is the fuel pump
File Type: jpeg
Old Jul 17, 2016 | 12:17 PM
  #72
Redog's Avatar
Just looking at Summit's website and it looks like I could get a Airtek or Spectra fuel pump that is 5 psi. Does this sound like my problem?
Old Jul 17, 2016 | 01:18 PM
  #73
svnt442's Avatar
Get a regulator and mount it as close to the carb as you can. The firewall or fenderwell is fine for that.
Old Jul 17, 2016 | 03:20 PM
  #74
Redog's Avatar
Procing the regulators, seems to be the same price or even cheaper, to just get the fuel pump.
Old Jul 17, 2016 | 03:26 PM
  #75
QJets need a max of ~7psi so your pump putting out 10 psi is causing flooding.
Old Jul 17, 2016 | 07:13 PM
  #76
Redog's Avatar
Yeah, I read 6, but that makes perfect sense. That's also why I couldn't get the edlebrock carb to stay running either
Just ordered a 5 psi pump from summit. Should come Wednesday. Also should be cooler Wednesday, I was dying working on the car today and it was t that hot
Old Jul 19, 2016 | 05:55 AM
  #77
distributorguy's Avatar
You also need to take the lid off the Edelbrock and set the float height/drop. They do NOT come factory pre-set, despite what the instructions say. That will cause flooding or fuel starvation. But fix the fuel pressure before you reinstall it. They run great when set up properly. Most people just never take the time to get them set up. No carbs work great out of the box, unless you are in the 1% that got super lucky!
Old Aug 30, 2016 | 08:27 PM
  #78
Redog's Avatar
I did this, turns out the one float was WAY out of adjustment. It wasn't 7/16" like it should be, it was more than an inch on the primary side. Put everything back together, restarted car, ran great, then stalled out again.
Althought the float needed to be adjusted, my neighbor was watching my fuel pressure gauge. The fuel pump runs and runs and runs, until it overheats and stops running. Watched the fuel pressure drop from 6 to 3 then to zero, and then it ran at idle for a good 3 minutes with no fuel being fed to the carb. The pump never kicked back on.
Turned off the car left it off for about 3 minutes, turned the key and the pump started pumping again.
So to fix this problem, I picked up a mechical fuel pump. It wasn't working before, something like it wasn't pumping, both the new and old fuel pumps. The old fuel pump was off my 307.
I picked up an ACDelco fuel pump. Part number 41566. However I have been unable to do any work on the car due to family issues right now
I was able to move the car on Monday for the lawn cutting guys. The weeds were only up to the door handle on the pass side
Old Aug 30, 2016 | 08:30 PM
  #79
Redog's Avatar
When I moved it, I was unable to break the rear tires loose by doing a burnout or by flooring it. The Inital timing is set at 21, the 1967 330 I have was set to 7.5 according to everything I've seen.
I reread this post and I see a lot of different numbers to try. I see 12-13 a lot. I also see 16-18 a lot. This is without the vacuum advance hooked up and line plugged. Didn't see any other open vacuum ports.
Motor: 1967 Olds 330 with 10.25:1 CR and 4 heads
Old Aug 30, 2016 | 08:35 PM
  #80
TripDeuces's Avatar
Is there a leak in the vacuum booster? Plug the carb port and see how it runs
