View Full Version : Small Blocks
- Stubborn crank key
- Difference in heads
- 307 high idle problem
- Very Annoying Water Leak!
- 55 olds fuel & wiper pump question
- getting a cam ground... thoughts?
- 1972 350 questions
- 403ci with diesel crank and rods?
- 55 Olds 324 dual point gap
- 470 truck avenger
- 1970 350 Rocket - Flexible Lines
- 73 88 engine change
- Rallye 350 IDLE !!! Vid
- Olds 340 build
- comp cams factory muscle 194h camshaft
- What is your recipe for rebuilding a 330?
- Overhaul Kit
- Timing Advance
- A huge Thank-you to CutlassFreak (Dave)
- Which headers 64 403 cui
- Top End Rebuild/Noisy Lifter
- 374 stroker Engine
- EGR valve ???
- Just picked this stuff up over the weekend
- New Exhaust
- Olds 350 engine
- HD/AC water pump vs non-AC
- Replacing Head Gaskets On My 330 (lots of pics)
- EMERGENCY: booby traps in stolen car
- Dual exhaust on 350 Delmont 88
- A debt of gratitude to Mr. Remmel (CutlassEFI)
- HEI weights and centerbars
- Hedman headers
- Harmonic Balancer bad wobble
- All info on a 72 Olds 350 7a heads
- vacuum takeoffs
- MSD 8566 for the Street
- roller tip rockers install trouble
- A huge Thank-you to 80rocket ( Don)
- 350 gold engine paint
- Excellent Writeup on Olds Engine Oil Flow
- TX Shop for Crank Pilot Drilling ?
- Help Needed
- '72 Cutlass 442 Not Starting
- Enginie id help
- interchange engine for 324 w/ standard belhousing
- Cam selection advice needed
- Will this work for hydraulic lifters too?
- No such thing as a stupid Question?
- Oil pans
- EFI Conversion
- Going Crazy!!!!
- Sweet piston deal !
- 403 builds and set ups.
- Is this intake still good?
- Power mods cutlass (72)350
- Commentary on newly rebuilt 350 engine running (video)
- Rear main bearing upper oil seal
- 350 rebuild kit
- manifold question
- swapping a 307 in place of a diesel
- cylinder head torques
- Unleaded Gasoline
- 66 330 going to hei...
- going electric
- SBO Max torque?
- Olds 350, no oil to rockers
- Power steering belt too tight?
- Buy the 403?
- intake gasket on 307
- Help w/TCI throttle/TV cable setup
- backfire at carb no power
- What does the number on the starter block mean?
- Tall stamped valve covers
- '72 vs. '76 Crank
- Thoughts on this build
- Carb issue maybe? 72 350
- 64 330 oil drain plug
- @ 050 dur and LSA of 393859 OE cam
- 7 or 5 heads?
- Water pump issues
- Strange idle behavior
- 403 solid web mains myth or real ?
- biggest dumb@$$ award goes to me
- CCC 307 fuel mileage problem...
- Turbobuild a lazy 307ci ?
- 72 Cutlass flex plate bolt size.
- 5 s or 7 s
- 403 Street built Advice
- Distributor vacuum control switch?
- 1976 Cutlass engine paint
- low buck build
- Timing gear whine
- Guide for properly lining up TDC w/distributor position
- 375ci Small-block Advice
- Advice on my 350 olds please
- 67 330 - single to dual exhaust
- Steel bolts in aluminum heads
- WHat is this mess? Engine id
- Electric Water Pump Questions
- need help figuring out my motor year
- Heat crossover ?
- Waterless Engine Coolant
- '71 350 throbbing sound at around 60 mph
- Header/ trans Linkage clearance issues
- carb qustion
- Vacuam Lines "PLEASE HELP"!!!
- Need help tuning 73 olds 350
- 324 fuel pump upgrade ?
- 403 main cap installed backwards
- Help....please
- 4 barrel
- crank pulley cover ????
- Thermostat Housing - Using Studs
- Got My Carb Back From the Rebuilder, BUT........
- Are All SBO & BBO Harmonic Balancer/Dampeners interchangeable?
- Shimming rocker arm pivots to adjust valve clearance
- SpeedPro Flat top Pistons
- Was my engine equipped with a 2-barrel or 4-barrel carb?
- Original motor color??
- Help! 307 stuck in fast idle!
- 62 F85 stopped running won't start
- Thermal Ported Vacuum Switch
- First start of the car, carburetor over flooding?!
- DEMON carb. transfer slot
- 350 rocket rebuild
- a/c removal
- Help help help
- Vacuum diagram meanings
- Suction from valve cover grommets
- 350 intake on a 330?
- Harmonic Balancer Needed
- 1983 Oldsmobile 98 307 Overheated
- Pro Comp Aluminum Heads on SBO - Intake manifold
- crossover pipe gasket?
- 1985-1990 307 parts
- Scorpion roller rockers
- 350 SBO Serpentine Conversion March Performance
- 15yo needs help with 330
- 1972 Olds Cutlass S Engine Knock...
- Oil Dipstick Tube
- Rochester Rod / jet questions.
- Float needle hook orientation
- Dropping Gas Tank - 70 Cutlass Supreme
- Engine Restart/Rebuild & Gauges - Oil, Temp, etc.
- Pro Comp heada
- Q-Jet. What did I break?
- Wont stay running! 73 cutlass supreme- help
- post 70's really that much lower compression?
- Full Time 12 Volts to Points Distributor
- carb and intake ?s
- hard start when cold
- 350 build advice?
- Notched valve covers on an SBO
- Carb Issues
- 7A or Edelbrock heads
- oil galley plug removal..
- Help finishing up valve seals and cleaning heads
- mechanical fuel pump for 72 cutlass 350.
- 403 airflow
- 350 heads
- High rpm miss
- 67 Cutlass 330 advice/ help please
- 307 olds
- 330 build with 350 sbc pistons
- 1986 cutlass
- 6 to 8
- Valve guide seals for #5 heads
- Fuel Tank Replacement
- Carb power hole
- 79 403ci SBO powerband
- 1965 330 with #2 heads, rocker nuts
- Is the intake valley baffle needed?
- Found some metal pieces around valve springs. please help identify
- 84 Olds Valve Covers
- One 7A and one 8 head on '72 4-bbl 350
- 68 350 Brake Booster fitting and hose
- 1970 350 Type "SO" Engine?
- Engine Builders/ Tuners in Ohio
- Problems after engine swap
- 1966 330 rebuild - forgot a few things
- 350 camshaft
- 350 identification and smog stuff
- 1969 Supreme 350 - Engine Code Location and HP?
- Hard starting problem
- Mechanical fuel pump alternator relocation
- Rings question (sealed power)
- Emissions Label Identification
- Odd-Fire or Even-Fire?
- Adjusting Comp roller tip rocker arms
- Bolt size for olds 350
- 350 engine detail
- choke range of motion
- 3A heads ,,slots'' ???
- timing chain Install 70 350
- '67 330 Quadrajet Problems
- 7042250 Jets
- Distributor and Coil upgrade
- Hesitation
- Squeak/screech from water pump pulley area
- Carb problems
- 350 build input?
- 1970 Cutlass, 350 L-74 Misfires
- 260 to 350 engine swap 80 cutlass supreme
- 350 camshaft
- Should pushrods turn?
- Low oil pressure light
- PCV Rattling/Cycling at idle
- quadrajet cleaning
- Emissions tag code help!
- Quadrajet restoration
- 330 cam options
- New Member (Tennessee)
- 350 stock cam specs
- Belt Question
- No Spark from my Daves Small Body HEI Conversion
- Holley 4160
- 350 head swap to 455
- 64 330, smoking very badly
- D/DX block and 4 bolt mains
- Gas Vent Issue, Aftermarket 350 Connecting Rods
- 350 Crank seal install depth
- When to use a spacer
- Back to SB heads on 350
- exhaust manifolds
- 350 heads
- Hate to bring it up again.........
- 68 Non AC 350 TVS?
- 307 timing??
- Power Steering Pulley- Endplay
- 1965 f85 econ-o-way v-6?
- part number for intake manifold gasket
- How much mechanical advance should there be?
- Ping when starting?
- Cam technology. this Progress
- 2 barrel to 4 barrel swap
- does this manifold work on orignal olds 350
- AC / non AC Alternator Brackets
- '68 350 Power Steering Bracket Mystery
- Rocker arm stud - bolt broken
- Rocket 350 automatic exhaust questions
- 2 barrel Flooding - HELP!
- Valve geometry question
- Quadrajet needle seat
- 72 Rocket 350 developed a sudden miss
- help recurving my 403 HEI
- coolant leak at front lower
- water pump removal
- info on valve seals
