exhaust manifolds
Old Aug 11, 2014 | 05:44 PM
deadeyejedi's Avatar
exhaust manifolds
hey guys need some help for a friend of mine he has a 1980 cutlass with a olds 307 in it doubt its original motor. we had a failed attempt to install a set of blackjack headers. no way they'll go in without picking the motor up and denting the hell out of them to make them work . I'm trying to talk him into stock manifolds will 350 rocket exhaust manifolds work on that motor?and any ideas where to get duel exhaust manifolds for a reasonable price? thanks
Old Aug 11, 2014 | 05:57 PM
There are no true dual exhaust manifolds for the SBO. They all have the crossover port on the PS manifold that needs to be capped.
Old Aug 11, 2014 | 06:01 PM
Good to know that would still be better than this header nightmare should I just be looking for used set ?
Old Aug 11, 2014 | 06:22 PM
Octania's Avatar
What?
What about Thornton's DE-only RH manifold?
http://www.ebay.com/itm/Oldsmobile-C...c0f376&vxp=mtr
$300 the set, bam, you are done.
And, yes, for any headers, esp. cheap ones, you can expect to lift the motor a little... and beat the snot out of interfering parts and/or cut off parts and move the brake junction, and...
Old Aug 11, 2014 | 06:29 PM
So is it safe to assume more expensive headers will fit better I'm considering them on my 72?
Old Aug 11, 2014 | 06:37 PM
Octania's Avatar
Assume?
Hella no
I have HEARD that Hookers fit right, but have never been able to use any.
It is more likely that higher end products need "less" banging denting and custom fitting, I would say.
I know it took a week of custom fitting and cutting to modify 68-72 350 Blackjacks to fit my '67 Cutlass with the 330 engine.
Old Aug 11, 2014 | 07:02 PM
I think I'll go with the thortons for my car the extra few horses you get from headers aren't worth the aggravation .as for the 80 cutlass maybe we'll keep pounding on the blackjacks thanks for the info always appreciated
Old Aug 11, 2014 | 07:13 PM
Paladin31's Avatar
I have a set of stock exh manifolds, #17 2506300 RH fits 260, 307 thru 87 a bodies, and a #1 380001 LH sbo, the #17 already has the crossover port welded shut. $60 for the pair + shipping.
Brett
Old Aug 11, 2014 | 07:18 PM
Octania's Avatar
A great cheap alternative. I have one RH manifold on which I brazed the crossover inlet shut with a piece of heavy stainless. Never found a buyer. It's pitted and would be dirt cheap at this time. #4 casting I believe.
Old Aug 11, 2014 | 08:01 PM
Chris, you're killing me. I am trying to restrain myself from commenting on this...
Old Aug 12, 2014 | 05:04 PM
the kid was determined to use the headers took two hours but got the passenger side on need to raise engine on the drivers side i think to do that thanks for the help and offers
Old Aug 12, 2014 | 05:38 PM
Paladin31's Avatar
Glad you got er' done.
Old Aug 12, 2014 | 05:53 PM
It's a bigger challenge at 50 than it was at 25 but I have more patience now
Old Aug 12, 2014 | 06:16 PM
Paladin31's Avatar
More patience, and more skin thickness...takes more repeated effort to scrap it down to the bone
Old Aug 13, 2014 | 09:59 AM
Octania's Avatar
Ha, did not see that
Everything in the garage sounds naughty
shafts
holes
screwing together
strippers [for wiring]
nuts
polishing your part
etc.
Old Aug 19, 2014 | 02:19 PM
gearhedjon's Avatar
Hold the phone...I ran true dual exhaust using stock Olds manifolds and not W31's. The problem with all right hand exhaust manifolds is you have to block off the extra port for the pipe that goes under the oil pan. If blocked, this still will disrupt the flow of exhaust gasses. So how did I get around this? 1978-1985 Toronado right side manifold. It doesn't have a pipe going under the oil pan as the trans axle is there. It can be used in a G-body (had mine in a 81 Cutlass) Fits perfect, exhaust is a straight shot no weird angles and doesn't hit the firewall.
bulky
Aug 28, 2006 11:59 AM
bulky
Jul 20, 2006 12:56 PM
linas9
Feb 23, 2006 01:10 PM
EdsDelta
Jul 22, 2004 11:46 AM
copper128
Mar 21, 2004 09:43 PM
