Hard starting problem
Hi Guys. I need a little input here on the fuel system. I have a 1987 olds 442 with a small block and a new fuel pump. If I park it for a day or two, I have to crank it for a long time to get fuel to the carb. I don't have this problem with my older SBC'S. What is the cure? thanx in advance Ed
Fuel tank venting
Another possibility, if the fuel tank vent is plugged, then the pump might be pulling a slight vacuum in the fuel tank. That may cause the fuel line to drain backwards a bit, assuming it can pull past the pump. It shouldn't pull fuel from the carburetor, but that might be a partial explanation.
I had an 86 olds years ago with the same problem (305 sbc) at first I switched to the clear inline filter to monitor how much fuel was draining back. I eventually had to change the lines as Eric mentioned.
cjprm
May 19, 2011 09:17 AM
