One 7A and one 8 head on '72 4-bbl 350
Okay, my new to me '79 Hurst/Olds came to me with a '72 350. Driver's side head is #8, but passenger side is a 7A (big A). I know they have a different combustion chamber size.
I haven't fired it up, but I plan to after I set timing and run a hot wire to the HEI distributor. The question is: How bad is this situation, will it run okay or explode, or shake apart?
I'd love to keep that engine in there as an occasionally light-duty driver if it runs okay. I'm the kind of guy who would rather put in a different complete engine (350 or 455) than change the mismatched head on a '72 350.
Thoughts?
Steve
Thoughts?
Steve
That is an odd combo! The 7A head is off of a 307, with tiny ports and a small chamber, the 8 is off a 73-76 350 with a large chamber. If it is a 72 350, it has crappy 23 cc dish pistons, more than likely it is a 73-76 which has 14 cc pistons, that would be better. Find some older 350 heads in decent shape and bolt them on or find a lower mileage 403 and drop it in.
Just curious, how does it run now?
I think he means he has a 72 350 head. The side of the engine with the 8 would be stupid low on the cr not to mention the worse exhaust flow. Personally I wouldn't drive it like that. Probably will run OK but it would be very slow and maybe hard to tune.
You are probably right, i just saw the "big A" and wasn't sure. Halfmoon, is the "A" as large as the "7" or smaller and offset lower? That would jive with it being a 72, also.
All I have left to do is set initial timing manually and run 12V to the cool transparent HEI dizzy and see if she'll run. I'll admit that I'm curious...
What a horrible combo. Decent compression and horrible flow on one side, other side, low compression and fair flow. #8 heads should be easy to find in decent shape for close to free, find another to match.
Since it has a #8 head on one side, I bet it has the 73-76 block/pistons in it. Pop on some older 350 heads, a little cam, and make it a fun little driver.
Unclear, as the different heads tell us that the motor has been apart at some point. Of course, the VIN derivative will tell you the year of the block and eliminate all speculation.
You are correct, but I am going to assume (dangerous, I know) that at least one of the heads is OE. But like you said, the number will confirm either way.
ohiocutlassparts
Sep 13, 2017 09:29 PM
70Post
Mar 1, 2010 08:19 PM
