PDA
View Full Version : Small Blocks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31]
  1. my 68 has some secrets....
  2. need some oldsmobile 350 info
  3. Buddy Bar Intake Manifold for Olds
  4. 71cutlass s hp & tq figures
  5. 1978 intake manifold
  6. engine block number....need help....decode it for me please....
  7. carburator calibration
  8. Valve Covers That Clear A/C Brackets
  9. ol4b carb recommendations
  10. if the 350 comes off a convertible
  11. hey guy a little help on casting numbers.
  12. 57 Olds vacuum line question
  13. new owner of a '53 98 - with questions
  14. Engine trouble
  15. 1966 400 oil pressure ?
  16. Cam question
  17. The car is an 88 cutlass
  18. 350 305 carb question
  19. Why when i give it gas it feels like i have to push it through the floor pan to go
  20. Type of Engine for my 85 Cutty for Sound
  21. 350rocket hp/torque?
  22. timing chain
  23. 330 to 350 overbore?
  24. HELP!! Need hot air choke tube...
  25. replacement oil filter
  26. replacement oil filter
  27. camshaft
  28. '86 307 vacuum & air hose problems
  29. Torque Converter 69 w31 conv
  30. motor
  31. Engine Identification Please
  32. New and Confused
  33. 350 rocket
  34. Diagnosis Needed - Oldsmobile Fouling Out
  35. will a small block swap out with a v-6
  36. newbie 66 f85 what engines fit?
  37. 71 choke tubes
  38. engine identification
  39. Air cleaner 1955 olds
  40. restore or soup up
  41. 1977 98 - cold starts fine then dies completely!
  42. chevy powered olds!!!!!
  43. would i be better off
  44. Whats my motor?
  45. more power out of a 307
  46. NEW TO FORUM
  47. Positraction
  48. Barrett-Jackson 55 Olds
  49. 350 rocket Question
  50. Oil slinger
  51. Stock HP rating for 77 olds 98
  52. Larger cam (or not)
  53. Carb swap and vacuum problem
  54. Valve/head specs
  55. A/C
  56. Headers
  57. More from my 350
  58. Should I swap
  59. 77 olds omega heater core
  60. Engine swap...
  61. 77 98 regency needs help
  62. 66 cutlass engine swap
  63. headers
  64. Newbee here , saying hello
  65. 84 - 307 locating water and oil pressure lines o
  66. 74 Omega header issues
  67. Location of engine Identification Numbers
  68. 1977 Olds 350 with Rochester 4bbl - car dies after first start...
  69. 350 Rocket Engine Temp
  70. headers for 72 cutlass supreme
  71. rear diffriintal convertion to posi
  72. seat options for a 78 cutlass supreme
  73. my car
  74. heater core installation
  75. Engine color
  76. Headers for '67 SB
  77. rebuilding motor question
  78. Help ?
  79. 1978 Omega NEED INFORMATION?
  80. HEADERS FOR OMEGA
  81. to much air in my fuel line
  82. Super 88 -59
  83. found short block cond.
  84. found short block
  85. Somebody can help me?
  86. Vacuum Hose help???
  87. exhaust bolt with stud
  88. small block to big block455
  89. headers
  90. intake clearance
  91. What Motor Do I Have (Help)!!!
  92. joaquin
  93. 303.7 3/4 race cam
  94. Hooker Headers
  95. OIL PRESSURE
  96. 307/350
  97. Redline on '64 330
