'86 307 vacuum & air hose problems
Old May 13, 2006 | 07:50 PM
jrbarrie83's Avatar
Question '86 307 vacuum & air hose problems
Hello! I recently purchased an 86 442 that had a remanned 307 High-Output engine installed at some point. The carb was also replaced with an Edelbrock. Some of the vacuum lines and all of the air pump lines are missing. Any ideas where I could find digrams showing the proper routing of these lines? I have a Helm service manual ordered to hopefully shed some light on this, but anything more would be greatly appreciated. We also found several electrical connectors simply lying on top of the engine. Any way to figure out what these should, or at least should have, gone to? The engine runs fine, but the service light is on. I'm assuming this has something to do with the vacuum lines and emissions system. Again, any input would be GREATLY appreciated!
Thanks!!!!
Jim
Old May 14, 2006 | 03:50 PM
Oldsguy's Avatar
Past Administrator
Jim, I am figuring the previous owner purposely disconnected those extra lines when installing the rebuilt engine. With an Edelbrock carb instead of the original there would be no place to connect some of the wires and perhaps some of the vacuum lines. And since the car runs well but the service engine light is on I would guess that it is in fact because of the engine swap. You probably won't be able to re-configure everything back to original unless you went back to the original engine. Possibly there are also sensors on the exhaust and block that are disconnected too. Man, if it runs good just run it and ignore the light.
Old May 15, 2006 | 06:25 AM
jrbarrie83's Avatar
Thanks for the info. I figured some of the things simply wouldn't go back. The only problem is, now that the car is in PA coming from Ohio, it has to have an initial emissions test, so the the air pump and vacuum lines will need to at least appear operational. I figured since we have the full gauges, we'll just take the bulb out of the service engine light, but it's getting the car past the tests so it's legal on the road that might be the issue.
Old May 15, 2006 | 06:44 AM
Oldsguy's Avatar
Past Administrator
Oh ok, I see what your problem is. That is tuff, if it is only a visual and not a sniff test, you might be able to do it. I am sorry I have no info for you as far as that goes but good luck.
Old Jul 9, 2006 | 09:26 AM
DonFrost's Avatar
go to autozone.com and look up your diagram there. as far as for the air pump go here to learn more about it. http://tech.oldsgmail.com/emis_AIR.php
chasman414
Jun 25, 2020 07:05 AM
RandyS
Nov 11, 2013 03:05 PM
hueveaj
Oct 29, 2013 12:53 PM
Jimoldsfan
Mar 2, 2013 11:47 AM
Rocketbrian
Dec 21, 2010 07:50 AM
