PDA
View Full Version : Small Blocks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31
  1. heater control valve help on new intake
  2. another newb question
  3. test
  4. Timing question on 54 Olds
  5. Engine swap
  6. Block number appears to be blank
  7. more power for my 403
  8. Leak at oil plug
  9. 330 pistons
  10. Thermostat Question
  11. oldsmobile 307 oil problem
  12. 207 3.4L Question
  13. a/c brackets
  14. 350 heads
  15. Eddies Performance Motors? Is 7200 to much?
  16. 371 cu. in. - some schooling needed
  17. Is this a ok install carb and intake combo?
  18. Spark plug gap
  19. whats a good year to snach a 350?
  20. Fuel pump replacement
  21. Interchange of 260 manual transmission parts?
  22. READ THIS GUYS!!! What a shame!!
  23. Spoiler Installation Question
  24. squeaky belt
  25. Timing problem?
  26. 403 Factory Engine color
  27. What year is my engine?!?
  28. Exhaust Manifold help
  29. remanufactured.com rebuilds?
  30. Starters
  31. GUYS I NEED YOUR HELP!!!
  32. Overheated! : (
  33. Eibach Lowering Springs
  34. Hi there got a question
  35. Rods and Caps
  36. Edelbrock Carb Vacuum Lines
  37. hey dipstick!
  38. Edelbrock on a 303 or 324
  39. firing order quetion
  40. Chevy into Olds
  41. carb
  42. 350 pistons
  43. Rebuilding a 350
  44. Carb Recommendation for newbe
  45. Hydraulic Lifter Preload on a 350
  46. Leaking fuel at carb
  47. 330 what plugs?
  48. Heads
  49. Aluminum intake
  50. Proper coolant mix
  51. Intake manifold
  52. Correct Fuel Filter?
  53. Radiator
  54. expected horsepower gains
  55. Flattop Pistons with #7 Heads????
  56. 1969 350 Camshaft
  57. 71 350ci
  58. Edelbrock Heads in way of pump
  59. Disc Brakes and proper vacuum
  60. New to the car need some help
  61. oil pan gasket
  62. Gas pouring out of carb
  63. 72 350 Rocket for Chevy
  64. 350 bolt up to jetaway?
  65. 403 build
  66. no power
  67. Quadrajet Float Level Adjustment
  68. engine bay
  69. OAI conversion question
  70. Harmonic Balancer Seal
  71. 330 help
  72. Help me wake up my 305 in my 78 Salon
  73. Dip Stick Tube replacement
  74. which weight oil?
  75. 330 rear main seal
  76. Header bolts
  77. Headers
  78. Idle -stop solenoid
  79. 371 oil valley plugs
  80. windage tray
  81. AC lines question
  82. Cutlass wont go over 25 mph
  83. where is the best place to buy a parts
  84. info about modification
  85. 350 intake manifold
  86. Octane use in lead gas motor
  87. Should I Convert To Fuel Injection?
  88. Horsepower and Torque???
  89. Where can I purchase gold paint for a 72' 350
  90. Pulling the heads on a 324 Rocket
  91. 68-69 Quadrajet the same ?
  92. Using compressed air to hold valve in place
  93. Alum intake
  94. 350 rebuild
  95. Car bogs on full throttle
  96. Good oil pressure
  97. Which cam for my combo???
  98. Pushrod not seating properly??
  99. Compression Ratio
  100. 74 cutlass vacuum diagram
  101. new to olds motor
  102. Valve covers
  103. The Pictures I promised, and more !
  104. '68 350 Hp and Torque mods
  105. 330 250hp? 400 cid ?
  106. 403 or 350? Which one?
  107. whats wrong in the picture
  108. carbs fits a 350 2brl?
  109. Carb question
  110. Young Owner Just Curious
  111. 403 Alternator/PS brackets diagram
  112. Carb problem?
  113. warning
  114. wheel question
  115. CAR WONT RUN FOR LONG
  116. Quite a bit of smoke from the valve cover
  117. Total noobie wants more power,
  118. Engine struggling noise
  119. #8 heads......doorstops?
  120. swapping motors
  121. 350 HP info
  122. dipstick too small
  123. intake/carb question
  124. 1977 Delta 88 Royale 'Indy Pace Car Replica'
  125. Restoration in 30 days
  126. 71 cutlass intake
  127. Spark plug condition
  128. Engine Heads (71 Cutlass Sup Convt)
  129. front cover for 350
  130. Olds Mechanic needed
  131. How to tell if I have the original engine?
  132. Pulling a 330
  133. Headers 324
  134. Finally going home
  135. radiator hose
  136. matching numbers how can you tell??
  137. Newbie: Engine Code on 88
  138. cam question
  139. Engine Question
  140. 350 rebuild
  141. Rocket 88 Holiday Sedan
  142. 307 heads on 350? bump compression up?
  143. Did I order the wrong part?
  144. 1970 cutlass supreme rebuild need help!
  145. headers
  146. how do i know if my engine is stock:S
  147. Starting issue
  148. '69 Olds 350 engine
  149. which valve covers to get ? moroso or edelbrock
  150. Interchange on 350 - 403???
  151. REBUILT KITS
  152. bought 77 Cutlass-have engine questions
  153. 350 or 403 ???
  154. My '56 324: Is the oil pump working??
  155. HP gains!
  156. 750cfm double pumper on an olds 350 ?
  157. Which Small Block Olds is Better
  158. Some1 W/ a 307 Y Do me a favor?
  159. how much hp
  160. Manifold Exhaust
  161. 350 olds to 455
  162. Dual exhausts for 1964 394 engine
  163. CHEVROLET VORTEX CYLINDER HEADS
  164. 71 olds 350 question
  165. 64 f85 intake help
  166. 330 carburator and intake help
  167. Which Spark plugs ?
  168. 71 cutlass
  169. olds 307 chevy 350 swap
  170. Leaky oil pressure sending unit
  171. mandrel bent crossover pipe
  172. 70 cutlass dist/vacuum control
  173. olds 394 help
  174. ac delete on 72 olds cutlass vert
  175. Valve covers-what do you think ?
  176. Compression Ratio?
  177. exhaust manifolds explained?
  178. Should I upgrade my 350?
  179. Need 1985 vaccum diagram...
  180. 350 REBUILD
  181. Compression ratio????
  182. Some engine questions...
  183. Heater blows hot air. Sometimes.
  184. Starting a new 350 build this weekend.
  185. freeze plugs?
  186. Help - rear seal / crank
  187. 3A vs 5A heads on 79 350
  188. Froze last night.
  189. Small block AC delete pulley?
  190. Oil Filter
  191. Edlebrock performer package
  192. 350 Small Block Upgrade Help
  193. Olds to Chevy
  194. Braided hoses question
  195. valve size
  196. 79 olds 350 buildup
  197. engine mounts 303 350 swap
  198. 400 vs. 403
  199. Will Olds 350 exhaust manifolds work on a 403?
  200. radiator stop leak
  201. Exhaust, The Final Tech Question
  202. Carb/torque Converter Tech Question for a 350
  203. 350 Valvetrain Question
  204. Coolant loss with our 350
  205. WIRING DIAGRAM?
  206. flush engine?
  207. Block off plate?
  208. crossmember 77-442
  209. Problem ? ring end gap
  210. Performance options
  211. 403 ?
  212. crossmember
  213. cylinder heads
  214. Choke problems?
  215. what year is my 350?
  216. 75 Cutlass 350 headers?
  217. Edelbrock Intake ID
  218. Blue Smoke From Exhaust Pipe
  219. New heads for my 86 442 plz?
  220. Motor & Trans for sale
  221. antifreeze question
  222. Replacing valve cover gaskets
  223. Red line on a 68 350
  224. 86 442 Timing tab.
  225. rebuilding engine in 84 cutlass supreme
  226. what motor due i have
  227. Painting the engine block
  228. 403 info please
  229. 307 start problem
  230. Engine Knocking
  231. where to find headers for a 74 Omega
  232. Engine casting numbers
  233. cam/carb for mid-13s?
  234. Covering holes on heads
  235. Engine Misses-Don't know what is wrong
  236. Timing and Spark Plug Gap for 350
  237. Timing tabs anyone ?
  238. Which carb ?
  239. BUICK Motors in Oldsmobiles.
  240. w-350 Intake or Edelbrock Intake
  241. Parts ID
  242. 455 heads on 350?
  243. 350 heads
  244. air cleaner questions ???
  245. t-stat or rad cap???
  246. edelbrock manifold on stock 350?
  247. How useful is this manifold ?
  248. Hedman headers
  249. headers or exhaust manifold
  250. hello again !
