whats wrong in the picture
Old Mar 22, 2008 | 09:09 AM
don71's Avatar
same but different
Take a look at this pic. It is a 1975 olds 350. Is this the correct dampner? IF it is, why is the timing cover bolt have its side ground off? Ok, so maybe its the wrong bolt. But WTF?
Old Mar 22, 2008 | 10:00 AM
To quote Monty Python, RUN AWAY!!!!
What's happened is that the rubber has failed, allowing the outer ring to slide backward towards the engine. DO NOT run this engine again until you've replaced the balancer!
Old Mar 22, 2008 | 10:25 AM
Wow! You see something new everyday.
Old Mar 22, 2008 | 02:48 PM
don71's Avatar
same but different
Ok, so its confirmed the dampner has spun and its junk.
I have a 1970 unit out in the shop, but I'm allmost sure its different. I'll be digging it out soon. Any chance I can use it instead?
Old Mar 22, 2008 | 03:05 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I'll bet the 70' will be just fine.
Old Mar 23, 2008 | 02:27 PM
Oldsguy's Avatar
Past Administrator
Good eye on that Joe. I just KNEW something was not right but couldn't figure it out. Thanks.
edit: as my Dad used to say "if it were a snake, it would'a bit me"
MDchanic
Non-Olds Engines
17
May 23, 2013 08:20 PM
joe_padavano
Mar 5, 2013 05:26 PM
Blackpage
Jan 23, 2013 06:32 PM
kjr442
Jul 25, 2011 02:11 PM
MDchanic
Nov 3, 2010 12:48 PM
