CAR WONT RUN FOR LONG
Old Mar 12, 2008 | 01:36 PM
71cuttyS's Avatar
Well here it goes. I recently put a 71 350/350 into my 1971 cutlass S. I finally got it running but once it gets warm it will stall out and not start again. The motor has HEI. I smelled bad gas so i took the tank out and cleaned/prepped it and re-installed. I then cleaned all plugs put them back in and tried the whole thing again but I still have the same problem. If anyone has any ideas I would gladly listen and try them. Also if you need more info from me just ask and ill post it asap. Oh if I let it sit awhile it will start right back up as if nothing is wrong. any help is appreciated.
thanks
josh
Old Mar 12, 2008 | 01:44 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Maybe your choke is operating backwards.
Old Mar 12, 2008 | 03:27 PM
Oldsmaniac's Avatar
You need to try and see what is causing the problem....Do you have spark when it dies? Do you have fuel at the carb when it dies? Is it flooding? The module in the distributer on an HEI has di-electric grease on the bottom that helps cool the module. Without it the module can overheat and give a no spark condition till it cools......These are places to start when it stalls.
Old Mar 12, 2008 | 03:49 PM
71cuttyS's Avatar
A good start indeed
I will start with all of these item this afternoon.
thanks
shamusj
Mar 4, 2016 06:48 AM
at3regency
Jul 12, 2015 06:08 PM
Chesrown 67 OAI
Alero
May 2, 2014 07:58 PM
WTony
Jul 27, 2011 06:41 AM
awspeich
Nov 30, 2006 07:28 AM
