more power for my 403
Old Jun 5, 2008 | 08:43 PM
bigron's Avatar
Talking more power for my 403
i bought a 403 small block for my '84 98 regency, i want more power but i dont have a lot of money to invest in it. my uncle said for me to get a better cam and some 7a heads of a '72 350, will that be fine on my stock 403 without major work or $. The car is pretty much a daily driver, i might have fun with it from time to time. Help me out
thanks
Old Jun 6, 2008 | 02:27 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You may run into a head bolt issue with the 350 heads. I believe you will have to have them machined to match the hole sizes on the 403 block.
A bone stock 403 would roast the tires all day anyway. Unless you're going to be racing the thing, I wouldn't even waste a good pair of 350 heads on it. but that's just me. Keep the 403 heads and Save your money up for a better rear end instead. That 2.41 1 legger you have will suck the life out of any motor you put in.
I want to go fast and on little to no budget Just doesn't go together unfortunately.
Old Jun 6, 2008 | 06:33 PM
You need to remove the oil pan, crank, and rotating assembly. Then you can weld up the open main webs. Or you can just do what I did and stick JB weld in there for some added strength.
Just kidding. Welcome to the site. A cam and some headers would really make that thing lively.
Old Jun 7, 2008 | 09:46 PM
bigron's Avatar
honestly i have about 1,500 bucks to get more power out of the 403, i got the new motor through my uncles friend pretty cheap, through research ive read that the heads on that motor arent too good and the cam wasnt good, so if i can get some of those things done would that help, including the intake? i got a 200-4r tranny on it so what rear end do yall recommend, this will be a street driver but i want power, i am saving more money for future work, just wanted feedback thanks
Old Jun 9, 2008 | 09:26 PM
Warhead's Avatar
#1...A set of 3.08/3.23 gears will make that thing a blast to drive, and still have decent economy.
A set of early heads with smaller chambers, and even a generic 214 cam and dual exhaust will shake the bugs out of most all street cars you run into. Recurve dist, block heat risers, ENJOY.
Old Jun 10, 2008 | 04:31 AM
You might want to get more info on the 200 4R. I am not sure if it will hold up behind a 403. I know it isn't the strongest transmission out there.
Old Jun 13, 2008 | 08:07 PM
Warhead's Avatar
ART CARR!
Some of his 200 4r's are running 10's. One of the turbo Booicks was in the 9's before they went to a T-400.
Old Jun 13, 2008 | 11:23 PM
88 coupe's Avatar
Junior Member
Originally Posted by Warhead
ART CARR! ........
http://www.cpttransmission.com
Norm
88hurstolds
Jan 20, 2020 11:39 AM
cutlassrichard
Sep 25, 2013 04:31 PM
65az
Apr 25, 2009 05:43 PM
mutzi
Nov 28, 2008 04:58 PM
mutzi
Nov 26, 2008 07:20 AM
