which valve covers to get ? moroso or edelbrock
Old Feb 10, 2008 | 12:09 AM
shaks 442 clone's Avatar
which should i get i found some used moroso's for 35 bucks or should i get some new edelbrock signature series for 40 ?
is either better then the other?
Old Feb 10, 2008 | 12:18 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I'd take either one. Sounds like a good price on both if they are nice condition.
Old Feb 10, 2008 | 01:28 AM
the edelbrocks would be brand new from work and with 30% off they might be cheaper the 40
the only thing is the moroso's are taller and i heard thats better for something
Old Feb 10, 2008 | 06:22 AM
Better for hitting your power brake booster when you drop the motor in
Old Feb 10, 2008 | 10:32 AM
dang thats true i guess i'll just stick with the edelbrocks unless someone else wants to chime in with another opinion
Old Feb 10, 2008 | 01:00 PM
I think the Moroso valve covers would be cooler.
Old Feb 10, 2008 | 10:52 PM
88 coupe's Avatar
Junior Member
I've always used whatever came with the engine, and bought beer with the money I saved.
Norm
Old Feb 10, 2008 | 11:39 PM
i think i could sell the stock ones for about the money if not more then the new ones norm
Old Mar 3, 2008 | 03:25 PM
dan2286's Avatar
Taller valve covers are used if you have a larger ratio rocker arm.
Old Mar 5, 2008 | 04:32 PM
Warhead's Avatar
Taller ones are used when you are running studs, and polylocks with an adjustable valvetrain that will not clear a stock valvecover baffles. The rockers usually do not have problems.
Old Mar 5, 2008 | 05:22 PM
dan2286's Avatar
Sorry about that, that does make more sense. Ive never personally had a need for taller valve covers, just from what I have heard from other people. Im sure you know how that usually works.
Old Mar 6, 2008 | 02:04 PM
88 coupe's Avatar
Junior Member
Warhead,
From ROP? If so, you will be an asset to the site.
Either way, welcome.
Norm
Old Mar 6, 2008 | 04:32 PM
Warhead's Avatar
Yup, the same.
Thanks 88!
Old Mar 16, 2008 | 09:40 AM
71 delta88guy's Avatar
Why not use aluminum covers? stock height,much better clamping force,looks so much better,won't rust after a year like the chrome ones do-been there already. Can be had for 75 to 200 bucks depending on condition. Clean up some grungy ones ,paint them and you're all set.
RAMBOW
Mar 20, 2017 06:58 PM
W31driver
Sep 20, 2012 04:44 PM
ethn_bert
Mar 19, 2012 09:29 AM
88hurstolds
Oct 6, 2011 08:26 PM
Olds64
Feb 17, 2009 01:20 PM
