Aluminum intake
Old May 7, 2008 | 05:18 PM
77omega's Avatar
Aluminum intake
There is an intake on ebay, the guy says its an aluminum 2 barrel intake off of a 350. Did Olds make an aluminum 2 barrel intake for the 350? Thanks
Old May 7, 2008 | 05:34 PM
Oldsmaniac's Avatar
I dont think they made one but they did make one for fuel injection used in the Seville.....it would look something like a 2bbl but has ports in each runner for the injectors.
Old May 7, 2008 | 06:01 PM
Rallye469's Avatar
My '79 with a 260 had an aluminum intake.
Old May 7, 2008 | 09:27 PM
77omega's Avatar
Will the 260ci intake fit the 350ci?
Old May 7, 2008 | 09:35 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
They will bolt up, but the ports will not line up.
A 307 one would work, and they're dirt cheap. Usually free.
Old May 10, 2008 | 09:47 AM
I wasn't aware of the aluminum 2bbl intake on the 260, but I can't say that I've paid much attention to those engines either. The A4 intake from the 80-84 307s is a good, inexpensive choice for an aluminum 4bbl SBO intake. Normal size ports, Qjet mounting pad. Avoid the later A5 intakes, which have the constricted runners that match the peanut ports on the 7A heads (not to be confused with the 7A heads...)
tocicar8825
Sep 21, 2021 07:10 AM
svnt442
Jul 17, 2011 04:43 PM
blonzz
Oct 25, 2004 02:19 PM
