rebuilding engine in 84 cutlass supreme
Old Nov 13, 2007 | 12:48 PM
cuttysss's Avatar
Question rebuilding engine in 84 cutlass supreme
i have a 1984 cutlass with the v6 where can i find the kit with all the gaskets and seals and also would a 454 fit in my engine compartment?
Old Nov 13, 2007 | 01:56 PM
dar83501
Guest
Posts: n/a
Look on ebay for a full gasket set.
and a Chevy 454 would probably fit, but you'd have to do some modifications or special work. You're looking at possibly getting beefier front springs, new transmission, reinforcing the crossmember, exhaust manifold clearance issues, hood clearance issues...somebody else would know more, I don't know how the chevy big block compares to the oldsmobile big block like i'm doing in my cutlass, but i know they are different. Those are some of the things i'm looking at for mine...
Old Nov 13, 2007 | 03:04 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
ewwww.
This sounds like a bigger pain than my Olds307-Buick350 swap.
I don't know. Joe Padavano on this forum is very knowledgeable when it comes to swaps and gave me some good suggestions.
If he is in a good mood he may even help you
That Ch**vy talk isn't going to have people jumping up to help you around here, even though the people are great.
Old Nov 13, 2007 | 04:53 PM
Redog's Avatar
Smile
Get an Olds 455.
Less modding to make it work
Old Nov 14, 2007 | 01:10 AM
88 coupe's Avatar
Junior Member
Originally Posted by cuttysss
........ where can i find the kit with all the gaskets and seals ........
The shop that does/will do your machine work.
Norm
Old Nov 14, 2007 | 09:14 PM
GoldOlds's Avatar
I don't think that swap would be TOO difficult; that Cutlass shares the same basic platform as the '78 to '83 Malibu, and there are TONS of people who have done the same swap in those cars (although most start off with an SBC, not a V6). You will need beefier springs for sure; the BBC is one heavy bugger of an engine - I don't know all the weights of every engine, but I'd bet the BBC is heavier than the BBO by a good 100 pounds. It'd probably be best to find a TH400 tranny and whatever you've got for a rad right now probably won't cut it. As with all '78 to mid-80s g-bodies, you'll want to do something about that 7.5" rear end too - any decent big block will chew it to pieces. If you use a Performer intake and a 2" drop base air filter set-up, you might be able to avoid hood clearance issues. I'm not sure about exhaust manifolds/headers. Order a set of block hugger/shorty headers for the Malibu of the same year and you should be alright.
- GoldOlds
Old Jan 15, 2014 | 05:36 PM
1935Olds's Avatar
I am getting my high performance gasket rebuild set from a seller on Ebay. You can check there.
Old Jan 15, 2014 | 07:43 PM
You should be able to get a complete gasket set from your local auto parts store, the intake kit may be sold separate.
Yes a 454 will probably fit, however you will need a trans to go with it. You can use sbc frame and motor mounts, new radiator, and front springs. Treat it like a Monte Carlo. The Gbody forum would be a big help to you.
Old Jan 15, 2014 | 08:01 PM
captjim's Avatar
You guys do realise that this thread is over 6 years old, right?
Old Jan 15, 2014 | 10:14 PM
Lars's Avatar
so what happened??? CO just threw it back out there
Old Jan 16, 2014 | 03:00 AM
captjim's Avatar
1935 olds probably did a search and it came up and he responded not realising the date.
Old Jan 16, 2014 | 06:06 AM
Arrrrrrrrrrrrrrrgh. I didn't even look.
zeppigio
Jul 11, 2014 09:37 PM
1935Olds
Feb 6, 2014 02:26 PM
cdoering
Aug 5, 2013 12:21 PM
russell-t
May 3, 2012 05:10 AM
cutlass47
Jun 27, 2009 04:04 PM
