Question - rebuilding 70 442 engine
Old Aug 5, 2013 | 11:17 AM
cdoering's Avatar
Has onyone rebuilt a 1970 olds 455 engine? If so, did you rebuild accoriding to the 1970 spec's (10.5 to 1 compression)?
The local speed shop told me with todays gas that 10.5 to 1 would need to be out of timing in order to run good (at leat not ping). And if you wanted to get on the engine it wouldn't last long. They said a 9 to 1 compression would be better. Thoughts?
Trying to keep engine as close to original at 370hp. I have original 70 442 W30 parts in the car (carb, distriburator, intake & exhaust manifold), Ram air hood & airfilter.
Just want to get others advice on rebuilding the engine (bore, pistons, cam). What parts should I order and where is a good place to get them.
Appreciate any advice from someone who really knows these olds engines.
Still deciding to put on F heads or E heads that have been altered to run on regular unleaded gas
thanks
Chris in St.Louis
Old Aug 5, 2013 | 11:56 AM
droptopron's Avatar
delete
If you want to run it on pump gas 9:1 or 9.5:1 would be better.
Old Aug 5, 2013 | 12:21 PM
cdoering's Avatar
Thats what I want to do. I'm guessing 9:1 for regular unleaded gas and 9.5:1 for super
zeppigio
Jul 11, 2014 09:37 PM
1935Olds
Feb 6, 2014 02:26 PM
cuttysss
Jan 16, 2014 06:06 AM
jensenracing77
Drivetrain/Differentials
Aug 14, 2009 12:21 PM
<NiN52445>
May 28, 2004 09:45 AM
