Is this a ok install carb and intake combo?
Old May 25, 2008 | 03:24 PM
BlueBlock350's Avatar
Hi fellas, I was doing some looking around on the internet and was on Advance Auto Parts website when I was looking for a intake manifold and carb combo, and I pieced together these :
carb- Edelbrock CARB 800CFM W/ELEC CHOKE EDLBR
Intake Manifold- Edelbrock PERFORMER EPS PERMASTAR EDLBR
Keep in mind that I have a 1977 Cutlass Supreme Brougham, with a 350R motor, is this ok? The website kept redirecting me back to chevy fitted parts is this ok? If so tell me what edelbrock stuff to use, if these things are ok, give me a comment and let me know. Thanks.
Old May 25, 2008 | 03:58 PM
Well, the intake mainfold link you provided is for a small block Chevy, so you'll have some difficulty getting that to fit an Olds 350. The bigger question, of course, is what have you done to the rest of the motor? If this is a stock 1977 350, an 800 CFM carb is a waste of money. You'll be hard pressed to flow 650 CFM. Also, if you want an Edelbrock intake, you need a 2711, 3711, or 7111. Period. Again, with a relatively stock low compression 350, the 7111 Perf RPM is probably out of your normal operating range. On the other hand if you have headers, a hotter cam, and higher compression, that 7111 might be a good choice.
Old May 26, 2008 | 06:43 AM
Well now that I know this I will just get a crate motor then, because by the time I spend the money trying to get a new cam heads and changing the compression I might as well spend the same money and buy a crate motor. Is that a good idea?
odddoylerules
Apr 21, 2014 07:54 AM
1968CutlassSupreme
Feb 8, 2014 07:06 AM
svnt442
Jul 17, 2011 04:43 PM
Kidcutty
Jun 4, 2011 08:57 AM
hawks70
May 26, 2011 07:07 AM
