squeaky belt
Old May 21, 2008 | 09:57 AM
80v8Cutlass's Avatar
squeaky belt
I have a bad case of squeaky belt,I only have the alt belt and the main belt that also goes over the ps. At idle its really quiet cant hear a thing but the purrr of the motor. its only when i give it gas does this happen and sometime it will go away after driving for a few mins the rest of the time it squeaks all the time.
Now it a pully was bad wouldnt it squeak all the time, and not just under load? I cllok and every thing lines up the belts look to be in good shape.
Old May 21, 2008 | 10:14 AM
Be sure the belts aren't glazed, but I'll bet the PS belt needs to be tightened. Most people don't realize that the Olds PS pump has two bolts and a nut that need to be loosened to properly adjust the belt.
Old May 21, 2008 | 10:17 AM
well i got in the car started it keep the rpms up alil and turned the wheel side to side and it didnt effect the noise untill i turned the wheel all the way to one side then omg it got 5x as loud....i had to stop after this in fear of someone calling the cop to report a murder in an old cutlass.
Old May 21, 2008 | 11:37 AM
Redog's Avatar
X2
Old May 21, 2008 | 11:40 AM
thanks for your help guys, ill check that belt. i need topost some pics today i found a few hoses that come off the carb with screws stuck in them = (.
Old May 22, 2008 | 12:50 AM
could this be the alt belt? tonight i noticed my dash light real dim when i started the car and after getting on the highway it light up. well ill try taking that belt off and seeing if this cures it tomorrow.
Old May 22, 2008 | 05:28 AM
If you suspect that your alternator isn't charging properly you can always have it checked at your local auto parts store for free.
Old May 26, 2008 | 04:24 AM
Joe sir you are the man, it was infact the ps belt....thanks.
Old May 26, 2008 | 06:41 PM
IDAS 69's Avatar
JOE IS THE MAN. I'm idas 69. New here but from what all I have read. Joe is the man on Olds.. Thanks for all your help too!!!!
Old May 27, 2008 | 03:54 AM
Jim's rare 80's Avatar
Jim's rare 80
Any pics of the 80 yet?
Old May 27, 2008 | 11:51 AM
Old May 27, 2008 | 11:55 AM
its mostly black now, im trying the rustolem thing....plan to get it pro painted but it will work for now.
Toronado76
Jul 15, 2015 09:43 PM
pmathews
Apr 30, 2014 07:14 PM
Seff
Nov 30, 2013 08:18 AM
Olds98
Aug 6, 2010 05:02 AM
72442
Nov 22, 2009 11:38 PM
