squeaky belt
Old May 21st, 2008, 09:57 AM
80v8Cutlass's Avatar
squeaky belt
I have a bad case of squeaky belt,I only have the alt belt and the main belt that also goes over the ps. At idle its really quiet cant hear a thing but the purrr of the motor. its only when i give it gas does this happen and sometime it will go away after driving for a few mins the rest of the time it squeaks all the time.
Now it a pully was bad wouldnt it squeak all the time, and not just under load? I cllok and every thing lines up the belts look to be in good shape.
80v8Cutlass is offline
Old May 21st, 2008, 10:14 AM
Be sure the belts aren't glazed, but I'll bet the PS belt needs to be tightened. Most people don't realize that the Olds PS pump has two bolts and a nut that need to be loosened to properly adjust the belt.
joe_padavano is offline
Old May 21st, 2008, 10:17 AM
well i got in the car started it keep the rpms up alil and turned the wheel side to side and it didnt effect the noise untill i turned the wheel all the way to one side then omg it got 5x as loud....i had to stop after this in fear of someone calling the cop to report a murder in an old cutlass.
Old May 21st, 2008, 11:37 AM
Redog's Avatar
X2
Redog is offline
Old May 21st, 2008, 11:40 AM
thanks for your help guys, ill check that belt. i need topost some pics today i found a few hoses that come off the carb with screws stuck in them = (.
Old May 22nd, 2008, 12:50 AM
could this be the alt belt? tonight i noticed my dash light real dim when i started the car and after getting on the highway it light up. well ill try taking that belt off and seeing if this cures it tomorrow.
Old May 22nd, 2008, 05:28 AM
If you suspect that your alternator isn't charging properly you can always have it checked at your local auto parts store for free.
Olds64 is offline
Old May 26th, 2008, 04:24 AM
Joe sir you are the man, it was infact the ps belt....thanks.
Old May 26th, 2008, 06:41 PM
IDAS 69's Avatar
JOE IS THE MAN. I'm idas 69. New here but from what all I have read. Joe is the man on Olds.. Thanks for all your help too!!!!
IDAS 69 is offline
Old May 27th, 2008, 03:54 AM
Jim's rare 80
Jim's rare 80's Avatar
Any pics of the 80 yet?
Jim's rare 80 is offline
Old May 27th, 2008, 11:51 AM
Old May 27th, 2008, 11:55 AM
its mostly black now, im trying the rustolem thing....plan to get it pro painted but it will work for now.
Toronado76
July 15th, 2015 09:43 PM
pmathews
April 30th, 2014 07:14 PM
Seff
November 30th, 2013 08:18 AM
Olds98
August 6th, 2010 05:02 AM
72442
November 22nd, 2009 11:38 PM
Quick Reply: squeaky belt
