View Full Version : Small Blocks
- 403 airflow
- 350 heads
- High rpm miss
- 67 Cutlass 330 advice/ help please
- 307 olds
- 330 build with 350 sbc pistons
- 1986 cutlass
- 6 to 8
- Valve guide seals for #5 heads
- Fuel Tank Replacement
- Carb power hole
- 79 403ci SBO powerband
- 1965 330 with #2 heads, rocker nuts
- Is the intake valley baffle needed?
- Found some metal pieces around valve springs. please help identify
- 84 Olds Valve Covers
- One 7A and one 8 head on '72 4-bbl 350
- 68 350 Brake Booster fitting and hose
- 1970 350 Type "SO" Engine?
- Engine Builders/ Tuners in Ohio
- Problems after engine swap
- 1966 330 rebuild - forgot a few things
- 350 camshaft
- 350 identification and smog stuff
- 1969 Supreme 350 - Engine Code Location and HP?
- Hard starting problem
- Mechanical fuel pump alternator relocation
- Rings question (sealed power)
- Emissions Label Identification
- Odd-Fire or Even-Fire?
- Adjusting Comp roller tip rocker arms
- Bolt size for olds 350
- 350 engine detail
- choke range of motion
- 3A heads ,,slots'' ???
- timing chain Install 70 350
- '67 330 Quadrajet Problems
- 7042250 Jets
- Distributor and Coil upgrade
- Hesitation
- Squeak/screech from water pump pulley area
- Carb problems
- 350 build input?
- 1970 Cutlass, 350 L-74 Misfires
- 260 to 350 engine swap 80 cutlass supreme
- 350 camshaft
- Should pushrods turn?
- Low oil pressure light
- PCV Rattling/Cycling at idle
- quadrajet cleaning
- Emissions tag code help!
- Quadrajet restoration
- 330 cam options
- New Member (Tennessee)
- 350 stock cam specs
- Belt Question
- No Spark from my Daves Small Body HEI Conversion
- Holley 4160
- 350 head swap to 455
- 64 330, smoking very badly
- D/DX block and 4 bolt mains
- Gas Vent Issue, Aftermarket 350 Connecting Rods
- 350 Crank seal install depth
- When to use a spacer
- Back to SB heads on 350
- exhaust manifolds
- 350 heads
- Hate to bring it up again.........
- 68 Non AC 350 TVS?
- 307 timing??
- Power Steering Pulley- Endplay
- 1965 f85 econ-o-way v-6?
- part number for intake manifold gasket
- How much mechanical advance should there be?
- Ping when starting?
- Cam technology. this Progress
- 2 barrel to 4 barrel swap
- does this manifold work on orignal olds 350
- AC / non AC Alternator Brackets
- '68 350 Power Steering Bracket Mystery
- Rocker arm stud - bolt broken
- Rocket 350 automatic exhaust questions
- 2 barrel Flooding - HELP!
- Valve geometry question
- Quadrajet needle seat
- 72 Rocket 350 developed a sudden miss
- help recurving my 403 HEI
- coolant leak at front lower
- water pump removal
- info on valve seals
- Finally runs
- 350 overheated now running rough
- strong exhaust at start up from my '71 350
- 350 camshaft
- Oil leak and hesitation.
- Engine Noise?
- Olds 307 Edelbrock carb problem
- by pass hose type ??
- Alternator fitment question.
- Oil dipstick?
- '67 330 stumbles at idle when hot
- Intake oil leak
- Used 403, what should I replace?
- 2bbl Choke Binding?
- Lunati W31 cam
- Metal in the filter
- Saving up money for the old money pit.
- Squash Squish?
- 1960 371 $300
- 403 in a 80's H/O
- New fan clutch
- chasing cold start misfire
- Intake/Exhaust Valve question
- head gaskets for 1977 olds 350?
- Radiator questions
- Planning for a future build for more power
- Gap in header flange
- 1969 ram rod w31 350 motor for sale
- 77-80 350 build?
- puzzled
- Idle rpm question
- Problem with a 403 throttle sticking
- Noisey valvetrain
- Olds 330 a few Carburetor questions
- Water pump replacement choice
- Radiator for 1972 Cutlass 350
- Temperature to high Oil Pressure to low
- OL4B Intake Question and Edelbrock covers
- Can someone tell me what this is?
- Rebuild or replace Engine
- Valve cover and oil pan restoration
- Why so much smoke???
- Ready To Run Distributor Install
- Factory mechanical advance?
- 61 f 85 trouble
- Help me decide my engine build...
- Prime new rebuild
- Injectors
- cruising along and car went kaput, so here................
- new to forum, have a Horsepower question
- I need more cow bell
- It's alive! It's alive!
- benefits from timing on stock motor
- Stock Dual vs. headers question....
- 350 Refresh advice
- 2 bbl trouble
- Carb hiss and overheat 72 olds 350
- rocker arm pivot hold downs
- 1st start procedures
- Carburetor advice.
- First Look 72 350...Thoughts?
- Turning over but not starting
- carb adjustment now worried!!!
- ID my pistons
- Head gasket issues need some input.
- timing chain install question
- 350 engine id ?
- Cam Guru Pick Me a Cam 330
- Vaccuum diagram
- 350 rocket new headers
- Massaging a 403
- tornado 403 firing order?
- Cam bolt question
- Engine build
- 350 exhaust
- 1965 Correct Valve covers
- 69 Cutlass 350 engine temp issue
- Vid of my new engine swap
- cylinder head gasket wrong?
- balancer diameter
- Engine random back fire when warming up and surging
- Couple carb/throttle questions
- Piston ring assambly....confused
- Can anyone identify what this is?
- What can I expect 1974 rocket with #6 heads
- SBO 350 GM educational motor.
- Olds 403 C-heads or #5 heads
- '64 330 head with BG suffix question
- no spark 330
- #5 Head build
- 1973 Cutlass S – Couple of things
- Installing fan shroud in a '70 S......help needed!
- X pipe vs H pipe
- Mechanical advance
- Broken bolt
- Flex plate to torque converter
- Any point in priming?
- '58 371 balancing/ dampner
- Thermostat
- what factory intake manifold can i use on a 330ci?
- 330 cam kit
- Couple questions for a slightly modified 330
- Question regarding engine temperature
- Debugging - '73 Cutlass S w/403
- 455 heads on SBO 350
- 1970 California Cutlass 350 question.
- Pulled my heads, they're cracked.
- Trying to get this 350 dialed in
- Olds 350 specific mild build advise needed
- What's it worth: 1974 350 from H/O, 1971 350 2V, both from junkyard
- Who makes the best Olds Gold engine paint
- Botched up success - RPM Intake install
- 1966 Cutlass 330 high compression dead cylinder
- w090898 head stamp
- Performer RPM Intake bolt #7 - how to remove
- Opinions - Spray Copper on Fel-Pro Head Gaskets, Yea or Nay?
- ´58 371 vacuum check valve
- Massive coolant loss - freeze plug?
- '73, 350
- Total timing (max hp)
- bolts for edelbrock intake swap
- Advice on adding electric fans to existing radiator
- Could this be the vacuum advance?
- Gutting 307 emission control vacuum lines
- Oldsmobile engine builder
- A few wiring, vac connections I am unsure of
- 330 Flush Questions
- molded 403 pcv to carb tube, where?
- SBO Performer RPM intake gasket?
- That cant be good
- Now a stuck distributor
- Need Schooling - Ticking noise and top end
- Carb advice needed
- quadrajet help!
- 307 alternator bracket question
- 69 350 connecting rod spit holes
- I want to add the bite to my Rallye's bark
- timing marks where is TDC?
- 72 350 rebuild ?
- Best way to block off water pump to heater core
- Running wire for HEI
- Need a torque spec
- Rocket or ramrod ?
- Olds 350 Rebuild
- carb issue
- Cam walk?
- Quadrajet choke
- oil pressure sending unit
- Talking cam, heads, pistons advice
- oil to top of engine 371
- Guess that mess
- How to remove a Power Steering Pump Pulley?
- Timing cover seal
- Vacuum issue? Carb issue? I have no idea what is going on
- Is it a 350 or 403?
- Swapping #6 for #5 heads
- Need Header Help
- Replacing the Carburetor
- 20 year old performance built 350 - Great find! (I think)
