69 Cutlass 350 engine temp issue
Old Jun 15, 2014 | 03:51 AM
DocAS's Avatar
Yesterday I had some issues with overheating. Usually my car runs around 200°F in city traffic and goes up to 210°/220°F at Highway. Yesterday at around 70 mph it ran up to 240° pretty quick and cooled back to around 220° within seconds.As I reached the next city it was back at 200°. After leaving city it began raising again between 220 and 230 but cooled down sooner, but I had to reduce speed due to traffic situation. Back home I checked coolant level which was good and there were no signs for boiling coolant. Even overflow hose was dry.
My bet is a weak thermostat, but I would appreciate any ideas from the pros out there!
Here are some facts about the car:
69 cutlass 350 factory A/C but deleted; everything else was left as with A/C
fan clutch is new
I am not sure about antifreeze/water ratio, but antifreeze hydrometer shows -15°F, thus ratio should be around 50:50
Thanks for any help!
Greetings from Germany
Old Jun 15, 2014 | 04:48 AM
DocAS's Avatar
When I squeeze the hose I can feel the spring. But it just reaches until the hose bends, so there are about 5" before the water pump w/o spring.
_____
Andi
Old Jun 15, 2014 | 05:18 AM
I'm not sure what you mean by a "weak thermostat", but there are two failure modes. If the t-stat opens prematurely, that won't cause over heating. I have, however, seen t-stat failures where the expanding capsule part of the t-stat failed, causing late opening, which would be a possible cause of your problem. Other possible causes are a partially blocked radiator (I've also had this happen) where crud blocked the lower 1/3 of the radiator and the collapsed hose. Other things to check are your advance curve (not reaching full mechanical advance) and carb jets (secondary jets might be blocked or restricted, causing lean running at spead).
Old Jun 15, 2014 | 06:54 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That is definitely on the warm side for a 350, even your normal running temps. Those are more like 403 temps. I would get a 180 or 195 Stewart Warner modified high flow thermostat. Then I would flush the cooling system, maybe even a double dose for a day or two driving and see what comes out. When you drain pull the block plugs too.
Old Jun 15, 2014 | 08:03 AM
I would replace the thermostat with a 180 degree Stant Superstat. Flush the radiator and replace coolant. It could also be as described by Joe, a severely clogged radiator that may require a radiator shops assistance to chemically clean, disassemble, and rod it out.
Old Jun 15, 2014 | 10:54 AM
DocAS's Avatar
Thanks for all the help!
joe_padavano,
yes I was thinking about a late opening thermostat.
I took the car for a ride today and it was about the same. Around 200° in the city, on highway it first dropped to around 190° (IMO because of higher airflow) and then went up to around 230°. It cooled then down to around 200° with me doing nothing. So I would stick to the theory of a late opening thermostat.
I don't think it would cool down without reducing speed if it would be a blocked radiator or a collapsed hose, would it?
I just ordered a 180° Superstat thermostat, not from Stant but from Gates since it is available around here. I will also change coolant and flush radiator when changing it. Let's see if it helps.
olds 307 and 403,
I would not expect the car to run cooler then around 200° with a 195° Thermostat, would it? It will allow the coolant flow through the radiator beginning at 195 +/- 5 and is fully open at around 210. Then cooling down to 185 or so until it closes and coolant will heat up again. Am I wrong about that?
This car really gets me used to US units
Thanks again
Andi
Old Jun 15, 2014 | 04:06 PM
M-14's Avatar
It might be more then a bad t stat, I'd take a long look at the radiator.
Old Jun 15, 2014 | 04:22 PM
Sampson's Avatar
Make sure your timing is correct. I had a similar problems before I got the timing 0'ed in.
Old Jun 15, 2014 | 04:28 PM
TAround 200° in the city, on highway it first dropped to around 190° (IMO because of higher airflow) and then went up to around 230°. It cooled then down to around 200° with me doing nothing. So I would stick to the theory of a late opening thermostat.
I would agree. Other things are possible, but that's your #1 likelihood right now.
Be sure you have an extra thermostat gasket (or two) for when it doesn't seal the first time.
Old Jun 21, 2014 | 06:39 AM
DocAS's Avatar
Thanks to everybody...the new thermostat fixed the problem! Temp does not exceed 190º at any driving condition!
The old one also was a 180º thermostat. It did not move at all when I put it in boiling water!
Great Forum!
Andi
Old Jun 21, 2014 | 07:09 AM
Just like it's supposed to work.
Glad you got it fixed!
Old Jun 21, 2014 | 07:14 AM
Well done
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
54oldz
Jun 20, 2012 07:13 PM
Emreozd
Feb 19, 2012 06:27 AM
brent
Sep 2, 2004 08:30 PM
