balancer diameter
Old Jun 13, 2014 | 12:05 PM
Macadoo's Avatar
Question balancer diameter
I'd like to get a timing tape for the '71 350 but I can't measure the damper's diameter directly without unbolting the pulley. I used the wife's flexible sewing tape measure and I get 20.5" for the circumference. Divide that by 3.14159 and I get 6.5253". Does that sound right? I can't find a tape for a 6-1/2" damper, only a 6". Is the panty (that's what it says on the back of the tape ) measuring tape inaccurate?
Thanks folks
Old Jun 13, 2014 | 12:19 PM
TripDeuces's Avatar
I ran into this same problem years back. You can do a couple things.
1) Use the short tape and fudge it knowing that the reading you see is actually less than actually. (Not reall happy with that)
2) Take your 20.5 inches and divide it into 360 and remark the damper as needed. Each inch being 17.6 degrees and every half inch being 8.8 degrees, etc. I did this using a hacksaw blade. It takes some finesse. Obviously the more accurate you are with measuring the damper circumference and marking off the degrees the better.
Old Jun 13, 2014 | 01:18 PM
Originally Posted by Macadoo
Is the panty measuring tape inaccurate?
No, the world is Chevy-centric.
You can get MSD p/n 8985, which is a series of 0-90 deg tapes for different balancer diameters.
Unfortunately, you'll note that the set does not include 6.5". I ran some numbers. If you use the 6.375" tape, at 40 deg indicated, your Olds will actually be at 39.2 deg. At 80 deg indicated, it's 78.5 deg actual.
Old Jun 13, 2014 | 05:02 PM
I ran into this issue, too, but I didn't know then (pre-internet days) that the tape was the wrong size. Didn't really matter too much as the tape flew off on the first couple of 5500 RPM pulls.
I did a similar thing but used white paint to mark lines on the balancer at 10º, 20º, 30º, and 40º. Then I could use the 30º line along with the timing tab's 2º increments to get an accurate reading of the total advance.
The good thing is those paint marks have survived over 20 years whereas that timing tape flew off on day 1.
Old Jun 13, 2014 | 06:16 PM
Macadoo's Avatar
Yeah, I thought about using my fine point white marker on black tape but I was afraid it wouldn't stick. The MSD was under $5 on eBay with free shipping so that works. I think I can compensate. Thanks for the calculations Joe.
Old Jun 13, 2014 | 06:19 PM
Macadoo's Avatar
Ugh, maybe I'll use contact cement. Done correctly (adhesive on both surfaces, letting dry) it's pretty strong stuff.
Old Jun 13, 2014 | 07:28 PM
Mac, e-mail me and I'll send you a pdf file I made up of a timing tape.
Just set your printer to print "actual size" and print it out.
The damper circumference is 20 7/16", for a distance of 0.0568" or 1.44mm per degree.
Therefore,
20° = 28.8mm
30° = 43.3mm
35° = 50.5mm
40° = 57.7mm, and
50° = 72.1mm
Old Jun 13, 2014 | 08:22 PM
Macadoo's Avatar
Email sent. Thanks Eric.
Old Jun 13, 2014 | 08:35 PM
Comin' atcha!
Old Jun 13, 2014 | 08:42 PM
Macadoo's Avatar
Thank you
Old Jun 13, 2014 | 09:05 PM
Print it out and make sure the measurements match what the sheet says they're supposed to be.
sshriber
Feb 25, 2012 07:36 PM
64starfire
May 19, 2009 09:56 AM
cts-v
Dec 30, 2008 07:34 PM
shaunr
Apr 12, 2008 01:22 PM
ztim
Dec 22, 2006 12:24 PM
