cylinder head gasket wrong?
Old Jun 13, 2014 | 03:26 PM
1966Oldsmobile's Avatar
i ordered a fel pro gasket set for my 330 cui. it is too small.it covers the upper cooling holes complete and the down ones half! is that normal? should i make the holes in the gasket bigger? thank you
Old Jun 13, 2014 | 03:46 PM
442Harv's Avatar
Do you have the old gaskets to compare them to? Non't know much about that engine, maybe the holes are suspose to be partially covered?
Old Jun 13, 2014 | 04:07 PM
1970-W30's Avatar
That's perfectly normal, the holes are purposely semi-covered like 442Harv mentioned.
Old Jun 13, 2014 | 04:25 PM
Keep in mind that those holes are there to allow the sand cores to be knocked out when the block is cast. They are much larger than they need to be for cooling. In fact, the holes need to be restricted to a certain size to force the coolant to flow all the way to the back of the block and not just past the first cylinder, into the head, and back out the t-stat.
Old Jun 14, 2014 | 01:28 AM
Great, thank you for your help! Its my first engine so i need some help sometimes.
Bobac455
Dec 4, 2013 09:23 AM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
