cylinder head gasket wrong?
i ordered a fel pro gasket set for my 330 cui. it is too small.it covers the upper cooling holes complete and the down ones half! is that normal? should i make the holes in the gasket bigger? thank you
Keep in mind that those holes are there to allow the sand cores to be knocked out when the block is cast. They are much larger than they need to be for cooling. In fact, the holes need to be restricted to a certain size to force the coolant to flow all the way to the back of the block and not just past the first cylinder, into the head, and back out the t-stat.
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
