Any point in priming?
Old Jun 6, 2014 | 05:00 PM
Macadoo's Avatar
Question Any point in priming?
I thought that'd get your attention
So the engine re-install looks like it might actually happen tomorrow. But I'll have all the accessories to get back on and the dual exhaust to install so is there any point in priming tomorrow before I put the engine in? Would it make the second priming (before first start) shorter and easier?
Old Jun 6, 2014 | 05:07 PM
Smitty275's Avatar
Engine Builder
Yes and yes. Make sure you have oil pressure gauge hooked up or the block fitting plugged off. Makes for one heck if an overhead mess otherwise.
Old Jun 6, 2014 | 05:28 PM
Macadoo's Avatar
Block fitting? Oh, do you mean where I have the oil sending unit screwed in? Oil won't splash out of the Distributor hole will it?
Old Jun 6, 2014 | 05:36 PM
RandyS's Avatar
No, there is no pressure in that area.
Old Jun 6, 2014 | 06:09 PM
Macadoo's Avatar
Thanks Randy
Old Jun 6, 2014 | 06:59 PM
TripDeuces's Avatar
You should be able to see the oil squirting out onto the distributor gear though if you look down into there
Old Jun 6, 2014 | 08:54 PM
I would prime it on the stand with the valve covers off. Insure that all your rockers are flowing oil prior to installing. It will take a few minutes with a drill, but I hate the surprise of no oil flow after I went through all the trouble of the install. Only to have to pull it out again.
Old Jun 7, 2014 | 02:14 AM
rustyroger's Avatar
'87 Delta 88 Royale
X2^^
Much easier if you find you have an oiling fault before installing the engine.
Roger.
Old Jun 7, 2014 | 05:01 AM
Macadoo's Avatar
Originally Posted by rustyroger
X2^^
Roger.
Understood. Let's just hope that's not the case. I read it's helpful to fill the oil filter before installing. Good idea?
Trying to get an early start. Supposed to rain this afternoon. I'll let you all know how it went (if it did) this evening in my "Pulling the motor" thread.
Thanks.
Old Jun 7, 2014 | 05:23 AM
rustyroger's Avatar
'87 Delta 88 Royale
If you prime the system you will fill the filter anyway.
The Buick/Oldsmobile 215 in its Rover V8 guise couldn't be primed because of the oil pump drive being geared rather than shaft driven. It was recommended that the oil pump should be packed with petroleum jelly to ensure minimal lag before oil got pushed round the engine. In that particular case it was a good idea to fill the oil filter before installing.
It's also a good idea to fill oil filters before instillation when doing an oil & filter change. Make sure the oil going in is kept clean!.
Roger.
Old Jun 7, 2014 | 05:25 AM
Smitty275's Avatar
Engine Builder
Remember to run the drill motor backwards or counter clockwise. Otherwise you might really be upset when no oil at all moves.
Old Jun 7, 2014 | 11:13 AM
Macadoo's Avatar
Engine is well primed, in it's nest, and we're trying to get it lined up as best we can. will update later.
BTW, tomorrow is Maggie's (my daughter's) birthday so she'll need a lot of kudos when we're done
Old Jun 12, 2014 | 11:13 PM
VinMichael's Avatar
I didn't prime mine. I was lazy
Old Jun 12, 2014 | 11:41 PM
rustyroger's Avatar
'87 Delta 88 Royale
How long did it take for oil pressure to build up?.
Roger.
Old Jun 13, 2014 | 12:03 AM
VinMichael's Avatar
Roger.
not long at all. the engine wasn't firing due to it not getting fuel. I cranked the engine until the battery got weak (which didn't take long to happen) maybe 30 seconds of cranking. At that time I pulled the valve covers, and the rockers already had oil on them.
Old Jun 13, 2014 | 12:09 AM
rustyroger's Avatar
'87 Delta 88 Royale
Taking the plugs out will also help you spin the engine for a bit longer if priming isn't an option.
Roger.
Old Jun 13, 2014 | 06:36 PM
Macadoo's Avatar
The engine actually primed in under a minute. I hadn't hot tanked the block so there must have been oil in the passages still.
Old Jun 13, 2014 | 07:28 PM
coppercutlass's Avatar
Chevy budget Olds powered
Mac was there oil coming from the pushrods ? I took me atleast 10 minutes with an air drill to do my last engine.
Old Jun 13, 2014 | 08:20 PM
Macadoo's Avatar
Yeah Copper, all the pushrods. Filled the rockers and over the side of the block. Glad I taped rags on the side.
Old Jun 13, 2014 | 08:21 PM
Macadoo's Avatar
Maybe I didn't use a heavy enough oil? 10w30 with a bottle of break-in fluid.
Old Jun 13, 2014 | 11:31 PM
rustyroger's Avatar
'87 Delta 88 Royale
You want oil getting round your engine ASAP, 10w30 should be fine for an engine built to modern tolerances,
Roger.
Old Jun 14, 2014 | 03:20 AM
I used 15w40 with a zddp additive. The oil psi went up fast but it took a while to get oil from the pushrods. I found it odd too. But never had issues with oil psi. The previous 2 engines I built it was fast like withing 3 minutes I had oil coming out the pushrods.
Old Jun 14, 2014 | 06:21 AM
Macadoo's Avatar
Maybe I should clarify; I got oil out the first pushrod in under a minute. Might have been 2-1/2 before it came out of all of them. I used Lucas zddp I think. I thought it odd but the directions were to fill with oil to normal capacity and add the entire bottle on top of it.
Macadoo
Oct 5, 2013 07:32 PM
442stang
Cars Wanted
May 27, 2012 06:56 PM
JRios
Sep 29, 2010 08:39 PM
dallasite21
Aug 31, 2010 07:54 AM
Wasted
Nov 22, 2008 05:59 PM
