Priming the Oil Pump 1971 Cutlass 350
Old Aug 30, 2010 | 08:35 PM
dallasite21's Avatar
When priming the oil pump should I get oil coming out of all valves. There seems to be a couplethat are not getting oil to come out. I dont know if that normal or maybe I didnt rotate the engine to a point where it would shoot oil from those valves. it is moving oil though. Should I be concerned or is this perfectly normal. I have attached a pic where you can see a couple that dont have oil on them.
Old Aug 31, 2010 | 07:54 AM
citcapp's Avatar
Rotate the engine several times to complete the oiling process. I don't believe you have a problem. What oil pressure is showing when you turn the oil pump?
Odmark
Jul 28, 2013 04:31 PM
Olds Scott
Mar 11, 2013 07:30 AM
84oldsDelta88
Mar 21, 2011 06:21 PM
JRios
Sep 29, 2010 08:39 PM
Wasted
Nov 22, 2008 05:59 PM
