2 bbl trouble
Old Jun 27, 2014 | 04:12 PM
tkheld's Avatar
2 bbl trouble
Freshly rebuilt 2bbl for a 67 330. Engine will start smooth for a couple seconds and then gets rough. Then fuel starts coming out of the bowl vent and pressure vent, engine stalls and will not restart.
Any troubleshooting suggestions would be appreciated.
Old Jun 27, 2014 | 04:21 PM
Oldsmaniac's Avatar
Seems like float level is too high, dirt under needle or seat, TOO much fuel pressure.
Old Jun 27, 2014 | 04:34 PM
Yuo, flooding from a high float level or leaky needle and seat.
Disassemble, re-check, and re-set float drop and level.
Also, is the float new? If not, are you sure it's not heavy?
Old Jun 27, 2014 | 06:24 PM
Octania's Avatar
pc of crud stuck in the needle and seat
Old Jun 27, 2014 | 06:32 PM
Oldsmaniac's Avatar
Yep a float that doesnt float would also be a problem. If its metal make sure it is dry inside. If its black composite make sure it is hard and not spongy as that will let it absorb fuel and it wont float properly.
Old Jun 28, 2014 | 08:11 AM
tkheld's Avatar
Thanks for the diagnosis - back to the disassembly.
Old Jun 28, 2014 | 10:43 AM
If the float is plastic, was it replaced in the rebuild? Ethanol in gasoline today will attack the plastic floats from the 1960s and 70s. I always replace the float when I rebuild a carb, and I always replace plastic floats with brass if I can get them.
Old Jun 29, 2014 | 09:12 AM
tkheld's Avatar
OK - new float - not brass. Float level adjusted to specs in chassis service manual. Float drop (1-9/16") seemed excessive - I think the float would rest on the bottom of the bowl - could I have the wrong size float?
Cleaned needle. New fuel pump. Same problem.
Old Jun 29, 2014 | 02:28 PM
Did you replace the fuel pump recently? Several years ago I had issues with 3 new ones putting out over 10 psi and causing flooding issues.
Old Jun 29, 2014 | 03:22 PM
tkheld's Avatar
Replaced fuel pump as part of troubleshooting. How do I determine if the new needle and seat are bad? This is driving me nuts.
Old Jun 29, 2014 | 09:20 PM
Note above that I went through 3 new fuel pumps and had the exact same over
pressure issue with each one of them. My point is installing a new pump does not rule out a fuel pressure issue. You need to actually measure the pressure in order to know that it is correct.
Old Jun 29, 2014 | 09:39 PM
m371961's Avatar
You mention float drop. Float height controls needle seating. With carb disassembled and float and needle installed, gently blow air in fuel inlet by mouth, raise float. You should feel resistance when/if needle closes.
There are better carb guys then me on here, just guessing and where I would start looking. Did this problem exist before carb rebuild?
Old Jun 29, 2014 | 09:59 PM
TripDeuces's Avatar
Float height and float drop are two separate adjustments each independent of the other. They both need to be done and accurate on a 2 bbl Rochester. Float height is adjusted by bending the float arm in front of the needle and seat and float drop is done by bending the tang behind the needle and seat.
Old Jul 3, 2014 | 06:54 PM
tkheld's Avatar
Installed new needle and seat...added a brass float for good measure...no more flooding. Thanks everyone for all the input and advice!
Old Jul 3, 2014 | 07:54 PM
Great!
ohiocutlassparts
Sep 13, 2017 09:29 PM
Uncle Hulka
Dec 28, 2011 08:17 PM
scott_442
Jan 21, 2009 05:19 AM
rontiac
Mar 24, 2004 01:26 AM
