Performer RPM Intake bolt #7 - how to remove
Old May 26, 2014 | 07:29 AM
wcourt3010's Avatar
I always struggle with removing this bolt. usually have to have my friend come in whose got more skills. Installation instructions list it as a 3/8"s - 16 X2" bolt. Any suggestions on how to get this bolt out? I can get it to move a little bit, maybe 2 full rotations but then it rises up into the plenum and i can't get a bit on it.
Old May 26, 2014 | 08:22 AM
I use an end wrench.
Old May 26, 2014 | 08:23 AM
Octania's Avatar
What drive mechanism? Std issue 9/16 across flats hex drive may not work.
Other options are reduced-size hex or 12 point head, or internal hex or torx drive.
Many times an internal hex drive [socket head cap screw] is required, and a ball end driver to allow tool access.
As for removing your intake and bolt, maybe you can remove all the others, loosen this one, move the intake a little, remove the bolt a little, repeat until it's out.
Old May 26, 2014 | 09:13 AM
RetroRanger's Avatar
72 Olds CS
On the rpm if your talking about the second bolt from the fr on the pass side idk how you got a regular bolt In there . I turned the head of a bolt like Octavia posted to even fit it there and even then it was tight. Edlebrock sells a bolt kit and that bolt has a super small head to it to clear the intake runner
Old May 27, 2014 | 05:15 PM
jag1886's Avatar
You need a longer bit and just keep wrenching on it to get it out, grind that allen bolt down a little once out and it will fit much better.
Old Jun 5, 2014 | 06:47 AM
wcourt3010's Avatar
thanks. i've switched over to the Edelbrock Performer and there's much more access to that particular bolt on the 3711.
Old Jun 5, 2014 | 05:14 PM
Sampson's Avatar
I am getting ready to purchase a new intake for my car and would be very interested in hearing more about your opinion of the RPM vs the Performer.
Old Jun 6, 2014 | 08:37 AM
wcourt3010's Avatar
sure. for me going with the performer was a smart move. i have a mild cam (Lunati 213/219 @ .050), highway gears (either 2.5X or 2.73 or whatever the numbers are). 750 CFM rochester quadrajet.
i put the RPM intake on a couple of years ago and immediately lost my low end torque. i probably should have taken it off and put the stock intake back on but i lived with it. the RPM did come on when i was at about 3-4K rpm. If i was doing say 60 miles an hour and stomped on the gas the car would really light up so there was definitely a benefit there but i wanted that low end torque back. as soon as i put the performer intake on without changing anything else i got all that torque back. I use the car mostly for just driving around town and occasional country road driving so its good for "light to light" fun. I can burn rubber now at the drop of a hat. i was thinking about changing those rear gears out for more torque but i don;t even think i have to do that now. i'm going to fool around with timing to see if i can get any more out of it.
as for install the performer went on with no issues at all. I remember having a hell of a time with the RPM and getting that little 3/8's bolt out was a real bugger.
agtw31
Feb 17, 2024 09:48 AM
70Cutlass_408
Jun 16, 2011 11:48 AM
Aceshigh
Sep 25, 2010 05:32 PM
GothamCity
Jan 4, 2009 05:12 PM
