350 Refresh advice
350 Refresh advice
What I have is a 73 Supreme, Stock 350/350 4bbl, factory duel exhaust, 2:73. and about 80K miles. I will install new top, paint and new seals. I have done a complete rebuild on the front suspension, and will go through the brakes, so as to start out fresh. So on to the drive train. The car will spend most of its road time between 65 and 75 mph. So I am looking to make an interstate cruiser. As such I will keep the 2:73's. I would like to install a 2004R transmission. The Engine ran good when I parked it 2 years ago. It has been changed to HEI. It needs new gaskets, cleaned and painted. I was looking at changing the timing gears and chain, and upgrading the camshaft and lifters. I will be running a Quadrajet. I know we got some good engine guys here, so I was looking for cam recommendations (other parts or ideas welcome) that would work well for this set up.
Thanks in advance, Blane
Sounds like a nice car...consider a compression test before any work is done to see if other work is needed and to get a look at the spark plugs. Would add valve seals to the list when doing the camshaft. If pulling the engine, install new freeze/expansion plugs and motor mounts also while it is out.
If the compression is good and it does not burn oil, I would not go into the bottom end of the engine.
If you plan on keeping the same compression ratio then I wouldn't change the cam, not much to gain there with low compression.
And if you're going with a 200-4R I'd change the gear to a 3.23 or so. That'll give you the best of both worlds, better acceleration and efficient cruising.
Go 3.42 or higher for gearing. I run 1850 rpm at 60 mph with 3.42 gears and short 25.6" tires with a 2004R. Add a 2000 stall converter and it will accelerate much quicker and still purr on the highway. Get a quality timing set to replace the nylon original. New gaskets and seals, except head gaskets should do if your compression and oil pressure is good. I put in a performer can advanced two degrees and it works OK in my original 76 350, identical to your 350. That cam is pushing it and is a bit large for the low compression. I still have very strong low end, was launching at 1900 rpm, soon 2500 rpm.
Thanks again
Have a look at www.shiftworks.com for a 4 speed conversion kit for your factory 3 speed console shifter. Their kits are nice and make it look like a factory 4 speed shifter.
If you really want a larger cam, think about swapping the #8 heads for some earlier 5, 6, 7, or 7a heads. Changing from the 80 cc original heads to 68 cc or so earlier heads will bump the compression up so you can effectively utilize the larger cam.
