coolant leak at front lower
Old Jul 29, 2014 | 07:24 PM
blkbety1977's Avatar
thought the water pump was leaking. Removed everything and got to the pump. At the front of the water pump nothing seems to be leaking there. At the bottom of the crank where there's a seal it seems to be dripping from there. Would this be a front seal? Meaning having to remove the crank pulley. there is a cover around that .... can that seal maybe be bad? Can this be replaced without removing the crank pulley? 1967 f85 with straight 6 250
Old Jul 30, 2014 | 03:36 AM
Yellowstatue's Avatar
There is a vent along the shaft of the water pump, and when the bushing inside starts to leak it comes out that vent and in your case drips on the crank.
Old Jul 30, 2014 | 05:37 AM
Thank you much. My other research shows there is no coolant that could leak from Crank area. I am in process of replacing water pump...hopeful that solves the problem.
Old Jul 30, 2014 | 06:21 AM
Water can leak from the crank seal. However if this is happening there are far worse things happening than just the water pump.
Old Jul 30, 2014 | 06:42 AM
What would that/they be? There is 25,000 original miles on car/engine. All original parts are there, including date coded spark plug wires. The oil has no milky look or feel, and is clean as can be, so I don't think there is a head gasket issue. where the coolant is leaking, it is green/yellow and clean, and does appear to have anything else mixed in...like oil, or other fluids. It runs like a top, and has no other issues except this recent leak. Would you suggest I continue with pump replacement, or try something else?
Old Jul 30, 2014 | 06:43 AM
there does NOT appear to be anything mixed into coolant...apologies for grammar error
Old Jul 30, 2014 | 06:45 AM
What I was trying to say is it can happen, but you don't have that issue. Since the oil is clean, I'd just change the water pump.
Old Jul 30, 2014 | 08:02 AM
I appreciate the help and advice!
65topless
May 6, 2013 06:15 PM
yeahbuddy
Apr 9, 2010 03:48 PM
olds88royalvert
Sep 10, 2009 05:03 PM
cutlass47
Tech Editor's Desk
Oct 7, 2008 06:29 AM
Diabolus
Jul 23, 2004 04:35 AM
