Bolt size for olds 350
Old Sep 4, 2014 | 10:42 AM
Alex72cutty's Avatar
I'm in the process of installing the motor on a 72 cutlass and I'm missing the water pump, flywheel, intake , and the bolts that connect the engine to the transmission. Would anyone know size etc. or a place where I can order new ones
Old Sep 4, 2014 | 01:12 PM
67442nut's Avatar
Should be 3/8" standard thread (9/16" socket size), 1 1/2" long.
The original bolts have a short shoulder, about 1/4"-3/8" long before the thread starts.
When I've got one apart, unless I'm doing a resto,
I replace original bolts with stainless ones for neatness and to reduce rusting.
Old Sep 4, 2014 | 03:31 PM
I assume you are talking about the bellhousing bolts, not the entire list.
In any case, the easiest thing to do is to grab these bolts off a car in a wrecking yard. They will be the same on just about any Olds motor (including the 307). This is about the only way you'll get the special bolt/stud fasteners used on the water pump to attach the accessory brackets. Flexplate bolts are high strength and should be available from the performance vendors. You can get stainless fasteners in a kit from Totally Stainless.
Old Sep 4, 2014 | 04:03 PM
Thanks!! Both replies are helpful. I pretty much need all except for the value covers
monzaz
Oct 13, 2020 06:28 PM
MN71W30
Apr 24, 2013 11:41 AM
Wildcard
Dec 9, 2012 10:35 AM
1973olds98
Ninety-Eight
Apr 29, 2010 08:03 PM
monzaz
Jul 6, 2009 07:51 PM
