Flex plate to torque converter
Old Jun 6, 2014 | 07:02 PM
Macadoo's Avatar
Hey folks,
I might have a lot of questions between now and tomorrow afternoon when I have my engine back in, so my apologies.
My flex-plate to torque converter "matching them back up" marks didn't survive the build. Will the assembly be unbalanced if I don't get it right? I figure I have a one-in-three chance
Old Jun 6, 2014 | 07:07 PM
Naah. Don't worry about it.
Old Jun 6, 2014 | 07:10 PM
TripDeuces's Avatar
It won't matter what position you put it in. The flexplate is balanced with the rotating assembly and the torque converters are balanced individually. They are exclusive of one another.
If you really think about it it makes sense. Otherwise you'd have to balance every drive train with the engine it was going with as a unit. No manufacturer is going to do that on a mass production line.
Old Jun 6, 2014 | 07:43 PM
Macadoo's Avatar
I thought I had read, some eight months ago, that I needed to be careful of this.
Thanks guys. One less thing.
How about spark plug boots to header flange clearance? I liked the looks of the right angle boot, cut them to fit perfectly, and voila, they're right up against the header flange. I can get maybe 1/4", 1/8" in a couple of spots. Live and learn.
Old Jun 6, 2014 | 07:51 PM
Octania's Avatar
Start all of the bolts before tightening ANY of them
Beware of too-long bolts
make sure you have a matched identical set
oh and the thread may be 10mm or 3/8, so TEST FIT THE BOLTS FIRST.
Old Jun 6, 2014 | 07:54 PM
The originals were straight, and I think those work the best.
Old Jun 6, 2014 | 07:55 PM
Tedd Thompson's Avatar
You are probably remembering a thread on 371-394 engines that are externally balanced and need to be matched up or bad things will happen(vibration)...Tedd
Old Jun 6, 2014 | 08:31 PM
Macadoo's Avatar
3/8" actually. I've tested fitted them like 10 times. Thanks Chris[?]
I thought there might be clearance issue with the AC box. All the straight boot wires I looked at seemed really long. Oh well, I'll make them work for the time being.
That's entirely possible Tedd. I'm just glad I don't have to worry about it.
Old Jun 6, 2014 | 08:35 PM
Macadoo's Avatar
But doesn't it look purty this way?!
[IMG][/IMG]
Old Jun 7, 2014 | 03:28 AM
Yes, but the whole point of the right angle boots is to avoid big loops of wire like you have there, on engines of a certain Division where the spark plugs are buried in between the exhaust manifold flanges:
Old Jun 7, 2014 | 04:58 AM
Macadoo's Avatar
Well sure, I know that now! I originally thought the boots would come out a little further, enough to clear the head. Then I was going to run them nice and tight under the valve covers. Like I said, I'll make due for now.
Old Jun 7, 2014 | 06:41 PM
I have that same style right angle boot and just point them as needed for the wires to clear.
Old Jun 7, 2014 | 08:09 PM
Macadoo's Avatar
Yup, pretty much what I'll have to do too. I'll decide later if I want straight boots.
AndySweden
Jul 23, 2012 09:40 AM
mauls
Nov 27, 2010 12:13 PM
cam40
Oct 8, 2009 05:16 PM
canucklehead
Dec 2, 2007 08:16 PM
Clint Reno
Aug 10, 2003 10:03 PM
