Valve geometry question
Old Aug 2, 2014 | 10:16 AM
Sampson's Avatar
I am changing my intake manifold today. I was looking at the push rods while I have the intake off. I can rotate the push rods on all the cylinders except the cylinders with the valves in the open position. Is this normal or a sign the valve is to tight. I used stock pushrods on this engine with a comp 268h cam that has .477/.480 lift.
Old Aug 2, 2014 | 10:21 AM
Smitty275's Avatar
Engine Builder
The valves that are closed should still have a little drag on them when you rotate them with your fingertips. If they are loose then your short on preload.
Old Aug 2, 2014 | 10:22 AM
The push rods tat are on the vales that are open have a load on them, the ones that are not only have a preload. What your seeing is normal.
Old Aug 2, 2014 | 10:26 AM
Sampson's Avatar
That's what I thought but wanted to verify while I am in there. Yes all have preload so I think I am good. Thanks for the input.....
1970_442
Aug 11, 2018 07:50 AM
e129745
Suspension & Handling
Jul 18, 2013 02:48 AM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
jpc647
Oct 12, 2012 03:11 PM
JRios
Dec 13, 2010 11:13 PM
