big valve E vs small valve E heads?
Old Feb 18, 2012 | 05:52 PM
1970_442's Avatar
i cant find any information on this, or im just looking in all the wrong places. can anyone clear this up. is there any noticeable difference between small valve and large valve E heads?
thanks
Old Feb 18, 2012 | 06:03 PM
2blu442's Avatar
Are you asking if there's any way to identify which size valves without pulling the heads off the engine? If so, then the answer is no. They're the same castings, the factory just cut out the valve seat for whichever sized valves the application called for. John
Old Feb 18, 2012 | 06:34 PM
Oldsmaniac's Avatar
The difference is valve size and small valve heads can be adapted to take the larger intake valves.
Old Feb 19, 2012 | 10:10 AM
1970_442's Avatar
is there any noticeable performance difference?
Old Feb 19, 2012 | 10:14 AM
2blu442's Avatar
That depends on how you drive it. I've always like the idea of larger intake valves, but I can't say that I feel a difference on a daily driver. We'll see what other members experiences are. John
Old Feb 19, 2012 | 10:34 AM
First, keep in mind that only the intake valve is larger (2.070" vs 2.000"). The exhaust valves were the same in both. The larger valve diameter gives you a larger valve curtain area, which is the cylindrical space between the valve head and the seat that is one of the bottlenecks in port flow. The larger intake results in a 4% increase in curtain area for comparable valve lift. Of course, the advantage of a larger valve (and thus more curtain area) is increased flow for a given cam lobe profile, but naturally the curtain area is only one element in total port flow.
Old Apr 8, 2017 | 08:56 AM
jpc647's Avatar
If they were still on the motor, between the casting number and the VPN derivative, could you determine what they are. I would guess a 2bbl car would ,more than likely have the smaller valves, where a 4bbl mighthe have the larger ones.
Although, that would assume Toro's all had 4bbls. And that's not the case.
Old Apr 8, 2017 | 09:49 AM
Originally Posted by jpc647
a 2bbl car would ,osteoporosis likely have the smaller valves
Well that's a new concept.
Old Apr 8, 2017 | 02:59 PM
Chesrown 67 OAI's Avatar
If they were still on the motor, between the casting number and the VPN derivative, could you determine what they are. I would guess a 2bbl car would ,osteoporosis likely have the smaller valves, where a 4bbl mighthe have the larger ones.
ALL big block factory 2bbl engines came with small valve heads. In 72 Ga Heads had small valves on the low-compression 4 bbl 455 engines too! Not sure if any E head 455 4 bbl motors had small valves? Joe P ??
Old Apr 8, 2017 | 03:47 PM
oldsmobiledave's Avatar
Fyi
4 speed & L-77 cars regardless of trans came with big valve Ga heads. All others came with 2.00" valves including the Toro. Up to & including 1971 Toro engines always had big valve heads.
Old Apr 9, 2017 | 04:23 AM
In 1970, only Toros and 442s got big valves. All other E heads got small valves. Of course, we're talking 2.000/1.625 vs. 2.070/1.625, so the difference isn't dramatic, and it's only the intake that is different.
Old Apr 9, 2017 | 04:28 PM
jpc647's Avatar
haha. smart as*. Sorry, I was sitting waiting for an appointment, and I was using a tablet. Didn't check myself.
Old Apr 9, 2017 | 08:33 PM
I figured it was an auto-incorrect but you never really know, a "medical condition" is appropriate when folks are talking about performance and 2 bbl carbs at the same time. Unless there's more than one 2bbl carb, that is.
Old Apr 10, 2017 | 03:54 PM
jpc647's Avatar
Haha. that's very true!
Old Aug 11, 2018 | 07:50 AM
Mikesmith455's Avatar
Mikesmith455
I have a 72 cutlass s with a 71 455 with fresh g heads new comp springs and 3 angel valve job and comp lifters and I picked up these c heads for 100$ just Wondering if it’s worth porting these ones and putting stainless valve?
Fullsizelover
Jan 10, 2014 04:44 PM
oldsy
Aug 24, 2013 12:56 PM
Hawk1061
Apr 2, 2013 06:44 PM
bosch 68 442
Apr 27, 2011 06:55 PM
jon 72 442
Aug 4, 2010 09:46 PM
