- zz small block
- engine identification help...
- 1982 Olds Delta 88 Royale ENGINE SHAKES SIDE TO SIDE????
- 1989 307 engine
- Looking for engine builder
- Whats a decent price?
- '73/'74 350 going into my '81 Cutlass Brougham
- hard to start after sit short time
- WMW reinforcement
- Olds 403
- differences between heads
- Edelbrock 2711 Intake not fitting my 1964 330V8
- Share the fun. 350 shower and shave
- I just couldn't do it! Bath tub gasket guidance
- A stupid question
- Stainless valves in OE sizes?
- Is this right?
- 455 in a 65 A body
- How is STP Additive Doing These Days?
- replacement carb advice
- 324 rocker ratio
- performer manifold provisions
- Another question from Oldsmobilliam
- olds rod bearings.
- Offy intake?
- 330 update
- 350 stock rods, any good?
- J-2 371 olds and trans/ Batwing
- engine dieing
- 350 over bore
- Back Again!!
- helpful hints
- Olds 350 Build
- Wobbly Belt
- Identifying Comp Cam
- paint color
- vaccum gage and timing
- 2 350's 1 week
- Fan shroud problem
- 330 CID Timing Mark
- intake manifold
- 403 rods
- Motor mounts 330
- Replacing oil fill tube
- Trans Am rear end in a Omega
- ticking 330
- Smoking 2
- Omega questions
- Q-Jet fairy!
- Torque Plate
- Head swap question on 350 sbo
- 72 Cutlass on Accel Website
- Any Experience with Quick Fuel Remanufactured Carbs?
- i dont know what to do anymore
- smoking
- Multi 2 barrel vs. Single 4 barrel induction
- 215 Aluminum, Do's and Dont's????
- Fuel Pressure, Line Sizes
- Edelbrock 3711 v 7111 v OL4B
- Starter Problems on 72 Cutlass
- cam thrust issue
- #8 Heads on a 70' Olds 350
- Edelbrock RPM Heads
- Differences between 1964 and 1965-on 330 V8s?
- QuadraJet
- 2 Questions?
- balancer
- intake, carb suggestions
- Aluminum radiators
- flowmaster exhaust
- Olds heads
- 1970 Rocket 350 recently rebuilt + TH350 worth?? Carb to pan, complete pull out
- 403/350 same?
- 1975 olds 350 timing
- Head Flow #'s on a 1970 Rocket 350??
- Sealing crossovers with the heads on the engine
- 330 #2 heads on 75 350
- 4bbl carb adapter for 303 square bore
- What should i do to the 307?
- fuel sending unit on 308
- 350 Carb Question
- I want some suggestions on my 350 rocket and 350 tranny.
- Which Intake/Carb for mild 350?
- HEI wiring up for older olds
- Best daily driver setup?
- Engine ID
- Few Questions, Hopefully get some good answers.
- thoughts on Demon Carbs.
- question about camshaft on pre '77 350
- engine casting #
- Air Intake Hose and engine sound
- headers - dual exhaust
- Running 87 octane in 307's
- this really sucks.
- 1973-1977 water pump
- The RIGHT water pump????
- questions about my 330
- 72 350
- Need a part# for a carb rebuild kit
- 350 gold engine
- Timing Advice
- O2 Sensor on 307
- plug gap and timing
- 69 quadrajet question
- Lifter question
- Scored a 330 Olds
- Best 4bbl intake to convert to EFI
- Original 350R
- Just bought a 1964 330 HC
- strange problem
- headers
- EGR block off
- 455 build need help.
- Need Your Input - Motor Build
- Engine ID ???
- Header Gaskets
- 12" electric fan replacing clutch fan
- 69 cutlass 350 tune-up
- Which Pertronix?
- Carb Question
- We need help!!! and lots of it.
- Really hot exhaust gas
- 330 Fuel pump... Same as a 350/400/455?
- 350 Rocket not running good after oil change
- SBO/BBO Valve covers
- Water Pump Question
- New Header Questions
- Hardened seats or not?
- 330 question
- Which 330 engine
- Looking for a fan shroud for 1970 442
- Quad 4 question
- How to store an engine
- Rebuilding 5 heads
- Cam Installation
- Dual Exhaust?
- Exhaust too raspy
- 403 valve covers?
- 350 help
- Newb with a '77 Cutlass Supreme Brougham
- Pusher puller?
- Cam break in question....
- 324 / 371 help. Blow by question
- Oil filter Recommendation
- Post Tune Up Issues
- '69 350 advice
- break in of rebuilt eng
- 330 to 350 swap NEED ADVICE.
- Newb ? RE: Head ID
- my olds 403cui donīt run good after tune
- felpro head gaskets
- Advice on 350 heads
- Loosing Prime
- Exhaust help
- Time for a tune up...
- 307..blue smoke!
- Vacuum question
- Tune up/points
- Oil Sending Unit
- Question
- Engine rebuild question
- Transmission/ radiator problem
- new guy need help
- Any preferred gasket?
- removing the gasket
- Olds engines
- radiator & heater hoses
- Boring after bored?
- The Ol'girl still has the stuff!
- Have 350 chevy in my 69 cutlass, any experience with this out there?
- This will be my olds 350 setup
- 425 cube small block
- Rebuilding and up grading my 350 rocket.
- Tuning a Rochester 4GC
- Knock / detonation upon acceleration ONLY when motor is hot.
- Fuel Delivery?
- Is this cam any good?
- 76 350 rocket
- Intake Manifold Question
- light ticking sound
- Why do Olds engine not always like aluminum intakes?
- General question
- Could I?
- Need Engine Compartment Decal Help
- Head ?'s and other ?'s
- Is it ok to run without a thermostat?
- fuel pump question
- Help I.D. Motor-if you can
- 303/324 heads
- Olds Rocket help needed
- edelbrock or holley?
- Fan Shroud
- Damn thing won't shut off
- Carb Problems
- GENERAL PERFORMANCE QUESTIONS
- #5 heads
- Head locating pins
- 330 cam recomendation
- 1971 oldsmobile cutlass with a 307 engine trying to find the year the engine was made
- 72 350 rocket
- issue with Factory Olds Hi-Performance Manifold
- 1972 350 Rod Bearing Question
- 74 Rocket 350 Upgrade questions
- Rocket 350 supercharger/ blower kit?
- 1956 350/LT1/LS1/LS6 engine swap
- more horsepower on my 403cui engine
- compression help
- Max valve spring lift on small block heads
- 71 olds 350 rocket rebuild
- How to raise the oil pressure
- Exhaust Manifold Gaskets
- Does this sound right?
- 403 motor mounts
- rough idle olds 350
- 307 to 403 swap?
- Correct Vacuum Hoses on 72 Cutlass
- 330 heads on 350 block
- Identifying my olds 350
- My pistons
- 200r4 tc
- torque converter?
- Couple questions
- Edelbrock Carburetor
- average cost
- Rebuild 330 or 350??
- Engine Identification
- 350 Machining
- Head Question
- What vacume advance springs should i use?
- no oil coming thru push rods
- knocking sound on passenger side
- What Carb for 65 330ci?
- new here--looking for help with a 215
- Rear Main Seal/Lower End Bearings
- I need a new distributor!!
- fixing a cast block?
- Looking for information on 76 350 motor?
- Cam and lifter suggestions
- Starting my '72 Cutlass project
- Backfire through intake??
- timing for a w-31 350 motor
- Valve Pan Covers
- Olds 330 ci VS. Chev 350 ci??
- 66 330 engine compression ratio
- 403 Heads on a 350?
- Engine ID help please!!!!!!
- Slight knock noise what could it be?
- crankcase pressure
- w/z exhaust manifolds on small block
