intake manifold
Old Aug 23, 2009 | 02:17 PM
oldsracer's Avatar
intake manifold
I've got an aluminum olds 350 intake I am thinking of using on my 403.I was wondering what your opinions on this are? It has the casting of CFD 3
22504068
near the thermostat housing is the letter/number A4
anybody know what this came off of?
Old Aug 23, 2009 | 02:59 PM
Bobsw32's Avatar
BobsW32
It will save some weight but there is NO performance gain.. SOme say they actually flow less than the their cast Iron brothers
Old Aug 23, 2009 | 03:53 PM
oldsracer's Avatar
well that sucks!
Old Aug 23, 2009 | 06:28 PM
Yeah, a 307. Fortunately, it came off a flat tappet 307 with the 5A heads, so it doesn't totally suck - unlike the A5 intake, which, since it is also aluminum, doesn't even make a good doorstop.
Old Aug 24, 2009 | 02:47 PM
oldsracer's Avatar
I am hoping I can go after it with some carbide burrs and put a spacer on top and make it a little better. If nothing else i will lose about 35 lbs on the front of the car.
Old Aug 24, 2009 | 04:38 PM
oldsracer's Avatar
this intake has a couple of things sticking up inside the primary throttle bores---should I remove these for a performance use? and what are they?
Old Sep 2, 2009 | 01:55 PM
oldsracer's Avatar
anybody?
Old Sep 2, 2009 | 02:17 PM
Those are the EGR ports. If you are not running an EGR valve, you can remove them and insert pipe plugs.
Old Sep 2, 2009 | 02:37 PM
captjim's Avatar
Not sure of your budget but Performers for a SBO are plentiful used in decent shape for $100. I am one of the minority that believes they are an upgrade over stock cast, plus they look better along with the weight savings. Just a thought.
Old Sep 2, 2009 | 03:25 PM
oldsracer's Avatar
I would love to put a performer on it but the class rules dictate stock motors. NO ALUMINUM INTAKES Im hoping I can get away with a stocker.
shamusj
Dec 18, 2014 09:28 AM
svnt442
Jul 17, 2011 04:43 PM
jjatich
Jul 29, 2007 07:57 PM
SMOKEYMTNKUSTOMS
Oct 12, 2006 12:18 PM
magnusdog
Sep 2, 2006 10:01 PM
